Power steering return line - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-14-2003, 08:07 AM
MaineJeep
The metal line that comes out of the power steering pump tank for the return line is rotted out. Is this peice of line replaceable? Does it come with the rplacement return hose? It doesn't appear to be threaded in like the pressure hose. Thanks
post #2 of (permalink) Old 04-14-2003, 08:15 AM
jeepgod's Avatar
Re: Power steering return line
you can make one out of brake line.. if you have a flaring kit.. to flare the end.. for the nut thats on your old line.. then use some p/s hose.. it doesnt have to be high pressure like the feed line..
my bust.. i was thinking gear box... not the tank..
jeepgod is offline
post #3 of (permalink) Old 04-14-2003, 10:48 AM
Most are part of the pump tank and not replaceable. What I would do is look at the wrecking yard and find a
pump with a good tank, probably the cheapest route. You may be able to buy them new also, Try NAPA.
What engine is the pump mounted to? I may have a good spare tank.
4x401CJ5 is offline
post #4 of (permalink) Old 04-14-2003, 01:36 PM
MaineJeep
thanks 4x401CJ5, its an 87 258.
post #5 of (permalink) Old 04-14-2003, 11:50 PM
The pump I have is off an AMC 401 V8, so I`m not sure it would work for your 258.
4x401CJ5 is offline
post #6 of (permalink) Old 04-16-2003, 07:25 AM
I have a PS pump from an 88 Grand waggie with an AMC 360. I know that a lot of the AMC parts do interchange with the I6, but I am not suer if the PS pump is the same. If you think the pump will work, and you want it, drom me an Email. [email protected] Shipping shouldn't be too much since I am in VT and you are in Maine. I also have the hydro lines that were attached to it.
Olin18 is offline
post #7 of (permalink) Old 04-16-2003, 07:32 AM
general420's Avatar
Jeep actually used GM power steering pumps. When searching the junk yard, just make sure the pressure line fitting is the same as GM used two different kinds, a flaired end, and a tapered end with an O-ring. I think you need the flaired.
JD
general420 is offline
