Re: leaky intake
1. Get out your manual..
2. It's time consuming to do the job right,
3. But not complicated.
4. Follow the procedure,
5. Be sure to use a torque wrench,
6. Put anti-seize on bolt, studs and nuts,
7. Soak EVERYTHING in PB Blaster before you attempt to remove bolts/nuts.
8. Be sure to do this on a COLD engine,
9. Repalce the intake/exhaust manifold gasket as a set at this time.
