Got it running now gas leak - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-03-2003, 08:48 AM
cj7_laredo
Just got my CJ7 running again (she's been sitting for just over a year). Replaced fuel pump, and cleaned carb, it has never run so good. Also bought parts for the TFI upgrade too(thanks LEVE!!)
A few minutes after shutting off I noticed gas leaking from the vent tubes at the tank (can be seen looking in from the drivers rear wheel well) lots of gas!! arent these vapor lines going to the evap. can. Also noticed a BIG gulp of air when I removed the gas cap. After relesaing pressure in tank leak stops. Should there be gas in these lines?
Robin
86 cj7 258
post #2 of (permalink) Old 03-03-2003, 09:05 AM
Re: Got it running now gas leak
[/ QUOTE ]1. There are several lines going into and out of the tank,
2. One to the fuel pump,
3. A return line,
4. Two vapor lines to the canister.
5. Where EXACTLY are you seening the leak?
a. From the Rollover vent tucked up in the drivers side rear wheelwell,
b. From the gas lines themselves?
c. From possible pinholes in the tank?
6. All hard gas lines terminate and flexible lines continue from above the tank to the tank inputs.
7. Also the hardlines cross over the front tank crossmember,
8. If the body mounts are bad,
9. The body comes down on the lines, crushing them.
10. For leaks check the:
a. Roll over valve,
b. The hard lines,
c. The flexible lines,
d. The tank's seam, where most pinholes occur.
post #3 of (permalink) Old 03-03-2003, 09:21 AM
cj7_laredo
Leak is definately comming from the lines not the tank, could be bad body mounts, I'll check tonight because the lines that are leaking are in the drives rear wehhelwell right over the frame. Not exactly sure what rollover vent is.
As she has been sitting for a while ther is more rust than I'd like to admit to.
