where does rear seat belt attach too? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-02-2003, 04:46 PM Thread Starter
got my rear seat and seatbelt today, problem is never had one so just wondering where do i attach the seat belt to? the floor or the seat? its going into a cj5
farmerbobrainy is offline
post #2 of (permalink) Old 03-02-2003, 05:04 PM
Re: where does rear seat belt attach too?
1. I'd anchor it to the same bolts being used to anchor the seat to the floor.
2. Do you have a Full Cage over the rear?
post #3 of (permalink) Old 03-02-2003, 05:09 PM Thread Starter
not yet, its the stock bar, but its tied to the frame at the front and rear.
post #4 of (permalink) Old 03-02-2003, 05:35 PM
I may be wrong about this but I thought that all CJs originally came with a rear seat. In that case, there should be some existing holes for the seat belts. Even my 66 CJ5 has the mounting holes for the seat belts in the tub right next to the tailgate and they look stock even though it does not have a rear seat right now.
ddieken is offline
post #5 of (permalink) Old 03-02-2003, 05:54 PM Thread Starter
when i bought my jeep it didnt have a rear seat or very much of a rear floor for that matter. i put on a fiberglass body and now have no reference to where it goes.
post #6 of (permalink) Old 03-02-2003, 06:30 PM
On my tub (86 CJ7) there is one bolt in the middle and one on either side. They're just behind the rear seat, straight under where the seat back is when it's upright in seating position.
80sCJ7 is offline
post #7 of (permalink) Old 03-02-2003, 06:42 PM
1. May I make a suggestion?
2. The OEM belts would be held in by the OEM bolts that held the back of the seat to the floor.
3. That in mind,
4. Mount the seat on the floor,
5. Mark the center of the mounting holes on the floor
6. Drill a 1/16" hole down through the floor.
7. Remove the seat.
8. Cut a peice of 3/16"X3"X3' plate,
9. Locate it under the rear flooring, under where the rear of the seat would mount.
10. Mark through the holes in the flooring onto the plate.
11. Remove the plate.
12. Drill the marks on the plate to 3/8" holes.
13. Weld 3/8" nuts to the underside of the plate.
14. Remount the plate, using bolts throug the floor.
15. Drill 6 1/8" mounting holes through the plate and into (not through) the flooring.
16. Remove the plate, prep, prime, and paint the plate
17. Mount the plate to the underside of the flooring using pop rivets.
18. Repeat the above for the front mounts.
19. Now the seat can be easily removed,
21. The mounts are firm, and won't punch through in an accident.
post #8 of (permalink) Old 03-02-2003, 08:56 PM
Official Curmudgeon
CJ7Taz's Avatar
It’s been a long time since I’ve had it installed, but as I remember on my ’80 OEM original, there were three seatbelt bolts across the rear lower rail of the seat on the vertical section. The seatbelts connected to the seat and the seat bolted to the floor.
CJ7Taz is offline
post #9 of (permalink) Old 03-02-2003, 10:32 PM
I think what it amounts to is, if it's the fold-and-tumble seat then the belts mount to the floor, and if it's the fixed seat then the belts mount to the seat (where it mounts to the floor).
80sCJ7 is offline
