Yellow sludge in valve cover - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-27-2003, 11:41 PM
I think I know the answer to this, but I'll proceed anyway.
I removed my valve cover to replace the gasket and the inside of it is coated with a greenish, yellow sludge. I've been noticing this stuff on the oil filler cap for years and some spurts out through the vent hose at the rear of the cover [and into the carb!].
I change my oil and radiator fluid religiously and have never noticed any radiator fluid in the oil or vice-versa.
What's going on?
Thanks to all in advance!
Chris
'85 CJ7/258
post #2 of (permalink) Old 02-28-2003, 12:06 AM
JeepnGreg's Avatar
Re: Yellow sludge in valve cover
my old CJ7 had that too.....moisture/coolant in the oil is what someone explained it to me as
JeepnGreg is offline
post #3 of (permalink) Old 02-28-2003, 12:16 AM
Sounds like you are guessing right.
If it was just a touch of whitish or chocolaty stuff I might
suspect condensation from your cold wet weather.
But the greenish - well, what color is your antifreeze?
Not good. The coolant kills the lubrication of the oil, so
you are killing your bearings, crank, cam, and rings with
it in there.
RRich is offline
post #4 of (permalink) Old 02-28-2003, 12:52 AM
Okay, now for the next question that I think I know the answer to:
Prognosis? TIme for a rebuild? How's the fluid getting in there? And why don't I see it when I drain my oil? Is it just difficult to detect?
Thanks for any and all advice/condolences.
Chris
post #5 of (permalink) Old 02-28-2003, 12:57 AM
1. Clean out the valve cover, and top end.
2. Fluxh the oil system,
3. Drop and clean the pan,
4. See if it returns, and
5. In how much time...
6. If it's condensation... you've got to
7. Run the Jeep longer to boil off the moisture.
8. If it ruturns in, like a few, days be concerned.,
9. Then check the coolant level,
10. And coolant for oil...
11. Does the goo smell of engine coolant,
12. As you said it has a slight greenish tinge.
post #6 of (permalink) Old 02-28-2003, 01:20 AM
moisture.... sludge.... looks to me me more like a blown gasket....
desertbuzz is offline
post #7 of (permalink) Old 02-28-2003, 10:37 AM
Okay, assuming the worst, I need to make a decision regrading rebuilding/replacing the engine. It has about 130k on it, so this doesn't come as total blow.
Quesitons, questions, questions...
Where is a good starting point in finding a quality rebuilt 258? What should I look for? Can I trust a place like Advance Auto Parts, etc?
Would I be better off taking my old unit somewhere for the work? I could probably live without driving the Jeep for a month if that's what it takes.
Also, I see that Advance Adaptors carries a bellhousing that mates the 4.0L to a T5. Anyone had experience with that conversion?
I've had this Jeep for four years and have driven the hell out of it. Commuting, toting kids, long drives to the beach, etc. This is my main vehicle and I plan on having it for a long time to come.
Thanks!
Chris
85 CJ7/258/T5
post #8 of (permalink) Old 02-28-2003, 10:48 AM
somebody correct me if i'm wrong but the 4.0 and the 4.2 aka 258 will take the place of one another. so no need waste $500 buying that. Personaly if the CJ is going to remain your primary driver go ahead ansd swap in a 4.0. i say while your at it put the fuel injection on it too.
http://wilhelm-tech.com/jeep/mods/40EngineSwap.htm
http://www.hescosc.com/catalog.html
http://www.jeepland.net/
http://www.rockcrawler.com/techrepor...swap/index.htm
heres a few links to get ya started. i've been researching this for a while now and bought a 92 cherokee wrecked with a 4.0 in it to swap it all over for $425 but it needs freshning.
post #9 of (permalink) Old 02-28-2003, 11:06 AM
RickB's Avatar
In my case, the 4.0 bolted right up to my 258 bellhousing for a T176. The T5 should bolt right up. The AA bellhousing may have a spot machined in it for the sensor that the 4.0 requires. This will keep it in the stock location. I bought the relocation kit for $189 and used my old bellhousing.
RickB is offline
post #10 of (permalink) Old 03-03-2003, 12:26 PM
Excellent! Thanks guys!
Chris
