Re: 95 Wrangler YJ Driving Lights
Depending on the wattage or candlepower, you really shouldn't be driving with them on while cars are coming towards you or in front of you. I doubt that anyone is going to check to see if they go out when you turn on the high beams also. I have my KCs (100 watt) hooked up to turn ON when I hit the high beams. I've personally have had no problems with them.
Just hook them up according to the manufacturer's instructions and you should be fine.
Oh, one other thing...
There is one wire that I have seen with most off road light kits that is supposed to hook up to the headlights at the plug that goes into them. This wire will determine when the driving lights turn on. You can hook this wire up to the wire for the regular beams, high beams, or the parking lights. It's up to you when you want them to turn on.
I hope this helps.
