I am shifting too low? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-19-2003, 01:26 AM
City ride. Stock YJ.
I shift gears at some 2000 rpm, sometimes a bit higher, but I never go over 2500 rpm.
Is it too low? I'm trying to shift as low as possible (MPG!) but NOT too low. But where's the limit, where should I shift?
post #2 of (permalink) Old 02-19-2003, 02:53 AM
Re: I am shifting too low?
That's about what I do..
Never take the engine abover 3000 when its in gear. I can blip the throttle up that high, and hold it, but not on the road. Doesn't feel right.
I didn't know there was a problem with shifting low.
Infernozx is offline
post #3 of (permalink) Old 02-19-2003, 03:20 AM
If you're too low on rpm, engine shakes, vibrates, wants to shut down. Like shifting in 3rd gear and trying to start moving without using the gas pedal - impossible.
When I shift, gears basically drop my rpm for some 1000 rpm down, meaning that when I shift @ 2000 from 2nd to 3rd, I get the engine running at 1000rpm, maybe something more. That's a bit too low - that's what I'm worried about. Then the combustion isn't right, then engine chokes.
If I got the theory right.
post #4 of (permalink) Old 02-19-2003, 06:23 AM
Unless your motor is actually stalling, then you are fine. I have to shift at 1000rpms all the way up into 3rd. I start in 1st. Get it rolling rpms up around 2K. Then I push in the clutch, I have to wait for the RPMs to come down to about 1K then into second. The motor does bog down a little. Once up to speed in second up around 2200 RMPs in goes the clutch again, I have to wait for the motor to drop to about 1K and then into 3rd.
I can get into 4th and 5th however I want to. The reason I have to do this is because the transmission grinds like mad if I don't. It is in serious need of a rebuild. I have been shifing like this for a while, and I have no ill effects.
As I am slowing down and down shifting, sometimes when going from 4th the 3rd I have to blip the throtle so that the transmission will go down into 3rd.
Olin18 is offline
