Need YJ Waggy44 Swap Pics please - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-18-2003, 07:08 PM
I'm about to swap in my 82 waggy front into my 89 YJ, using a SOA setup. I'm about to buy some ubolts for the driver side, and wasn't sure if the ubolt closest to the knuckle hung on the cast part, or wrapped around the axle tube. I was considering using square ubolts (anyone done this?) if they hung on the diff.. I've searched, but many of the pic links are no longer working.. Thanks a ton!
post #2 of (permalink) Old 02-18-2003, 08:07 PM
Re: Need YJ Waggy44 Swap Pics please
check here. there are a couple decent pics
http://stream.asap.um.maine.edu/~pul...tegory=Archive
one u-bolt is right at the end of the cast. The other u-bolt is right on the cast. you can see this in a pic. I was going to use a square one for over the cast part but instead I grinded and welded in a chunk and used a round u-bolt. Mike
pbytrailz is offline
post #3 of (permalink) Old 02-18-2003, 11:47 PM
Thanks! Helps a ton.. Do you remember what size ubolts you used? I was looking at getting two 9/16"x3"x7" round ubolts for the pass side, and two 9/16"x3.5"x8" round u-bolts for the driver..
What "chunk" did you exactly weld on? Do you mean you made a support for the outside ubolt(so it does pull off the cast)? Thanks again!
