TR's alternator wiring diagram w great success! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-18-2003, 03:11 PM Thread Starter
TR\'s alternator wiring diagram w great success!
Just wanted to draw more attention to the old posts about how to wire up a Delco alternator.
Link to TR thread
Someone drew my attention to it a couple of weeks ago regarding delco alternator wiring.
I followed the instructions and must report back that it works with great success. The alternator now maintains the wiring harness at regulated voltage regardless of how much current the accessories consume (unless it is at idle and the accessories draw more than the alternator can generate). Previously, as I turned on headlights, two heater fans, etc, the voltage on the harness dropped, as voltage was being regulated at the alternator to battery connection, instead of at the loaded end. And here I thought there was something wrong with my alternator. It's just the way the factory wires it up, doesn't compensate to the accessories for load, as it regulates battery voltage, not wiring harness voltage. And the idiot light is not a bad idea either in conjuction with a voltmeter.
TiminMb is offline
post #2 of (permalink) Old 02-18-2003, 04:05 PM
brendan
Re: TR\'s alternator wiring diagram w great success!
2 questions:
1. I'd like to hear a horn that needs a Relay! Is this lead just any switched +12 wire from the fuse block?
2. What is the function of the "A" terminal? It grounds to light the idiot light, correct? In what situation does it ground?
Thanks, Tim. Maybe just point me at another thread?
post #3 of (permalink) Old 02-18-2003, 04:18 PM Thread Starter
Wiring Jpg
The thick red wire with a white stripe coming out of the harness connector on the firewall has ignition switched 12v power. This can be used for both powering the idiot light and the alternator sense line (B). Run two wires off it. One 12 gauge to the alternator, another lighter gauge wire behind the dash for the idiot light. The other side of the idiot light then runs to the alternator exiter terminal. Don't use a grounded bulb. Buy an indicator light that has two terminals.
The idiot light comes on when the ignition is turned on, but the alternator is not operating. It will remain on if the alternator fails to charge and (apparently) will blink if there are rectification problems. It goes off once the alternator begins charging and producing output. It serves as both an indicator of a charging problem and the needed resistance to the alternator excitor input. The factory wiring on my 84 has a brown solid resistance wire running from the harness to the alternator.
TiminMb is offline
post #4 of (permalink) Old 02-18-2003, 04:22 PM Thread Starter
Essentially, "A" turns the alternator on and off (and needs to be a source of switched 12v thru a resistance wire or idiot light) and "B" is the input to the regulator, and where you hook it up determines where the voltage is referenced from.
TiminMb is offline
post #5 of (permalink) Old 02-18-2003, 04:24 PM
brendan
OK, Thanks Tim. I have the resistance wire as well. I was wondering how that figured into the equation. I may do this in the next few days(layoff) since I have not yet got my voltmeter.
post #6 of (permalink) Old 02-18-2003, 04:38 PM
I don't mind giving kudos to the individuals responsible for this information. I wired it verbatum in my 87 YJ 4.2. and after running 60 feet of 2 guage ground cable to a multitude of different points in my Jeep I am FINALLY running 14.9 volts steady. I was replacing batteries yearly and my lights would flicker when using anything(stereo, heater, turn signals, etc.), and now my gas guage works, my lights have never been brighter. Props to Team Rush. [img]images/graemlins/goodpost.gif[/img]
bloodly1 is offline
post #7 of (permalink) Old 02-18-2003, 07:17 PM
Why not just convert it to a one wire alternator and not worry about anything else? [img]images/graemlins/RockOn.gif[/img]
lindy80cj7 is offline
post #8 of (permalink) Old 02-19-2003, 07:50 AM
From what I understand the 1 wire alt. won't charge very well at idle rpms.
JimmyZ is offline
post #9 of (permalink) Old 02-19-2003, 07:54 AM Thread Starter
The one wire alternator samples voltage internally, that's just what I am getting away from. By running the sense wire out of the alternator and into the main harness where voltage drops due to load, you get regulated voltage at that point. A one wire alternator can't sense voltage drop thru the wiring. That shouldn't be a problem, but automotive wiring is light duty and with fusable links, a voltage drop is certain.
TiminMb is offline
post #10 of (permalink) Old 02-19-2003, 05:44 PM
I just did my Delco! Thanks for the reminder Tim!
1977CJ7 is offline
