Anyone used YJ shackles on CJ7 ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-18-2003, 04:10 PM Thread Starter
I want to know if I can use a set of YJ shackles on my 83 CJ7.
I want to do that because YJ shackles are 1" longer than CJ7 one's so that would give me a 1/2"lift and that I can have easy access to one set.
The issue I see is the bolt size. I haven't measured yet but it seems that YJ bolts are bigger than CJ's.
Anybody as done this ?
oldp is offline
post #2 of (permalink) Old 02-18-2003, 04:26 PM
BMB
Re: Anyone used YJ shackles on CJ7 ?
Not sure about the bolt size, but CJ front springs are 1/2 inch narrower than YJ fronts.
BMB
BMB is offline
post #3 of (permalink) Old 02-18-2003, 04:44 PM Thread Starter
I know springs are narrower on a CJ, but on stock YJ shackles there are no spacer so thats not a problem.
However bolts diameter is a problem if the hole in the shackle is larger than the hole in the bushing..
I talk to 4WD Hardware people an they say that I can use their YJ shackles (thay have a spacer) on my CJ. However when I ask about the spacer size thay say that I would need to cut it and they didn't answer yet about the bolt issue..
maybe someone here knows better ...
oldp is offline
post #4 of (permalink) Old 02-18-2003, 09:19 PM
BMB
Spacers? Never heard of any shackles using spacers, but I guess they can. I'm guessing if the bolt size is different you could use YJ busings in the CJ springs and it should all work out.
BMB
BMB is offline
post #5 of (permalink) Old 02-18-2003, 09:38 PM
I used the YJ shackles on my CJ, an 81 CJ7, when I first did my lift. The old CJ shackles were rusted so bad that a couple of the bolts were rusted to the shackles and I didn't want to use them again. They worked ok but I wanted a little be better shackle so when money became free I ordered a set of aftermarket shackles. Good luck.
stranger is offline
