Sheared 4 Wheel Studs and lost a Wheel - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-20-2003, 04:54 PM Thread Starter
Pog
Well I now know I have the worst luck cause on the way home from work today I got a werid vibration from the front end I thought it was just the snow build up. So I pull over look at everything and it seemed to be fine... but at the last turn I had to make my damn wheel fell off. I only had one stud left so I limped home on it (like a block) But this is the second time I have had loose wheel nuts, I think someone is trying to get my tires cause with there only being one lug left on there I figured it was the locknut stud. Anyways enought introduction, I have one question can the new studs be installed without the removal of the front drive or can they slipp inbehind and be pulled through it's a dana 30. Just thought I would ask cause it is dark cold and late here so I have to get it fixed before school in the morning. Oh yea last time I got studs and nuts from the dealer they were like 6&8 dollars each anyone know of aftermarket that would carry them in stock?? thanks James
Pog is offline
post #2 of (permalink) Old 01-20-2003, 10:36 PM
Re: Sheared 4 Wheel Studs and lost a Wheel
You gotta take it apart. The studs hold the disc to the hub and are press fit. I don't think that you can pull them through like you can on the rear.
Fritz
ExtinctJeep is offline
post #3 of (permalink) Old 01-21-2003, 12:32 AM
You'll have to take the rotor off to change them, I'm pretty sure.
Advance/Checker/Kragen/Schucks has the studs for $0.99 each, part 98188
dschwab9 is offline
post #4 of (permalink) Old 01-21-2003, 06:21 AM
elusive's Avatar
yes, any parts joint has the studs..
heres a hint.. when you are putting the studs through the rotor use a lug on the front with an impact wrench to seat them..tap on the back of the stud while you crank on it with the impact. this should only be a 1/2 hour job costing you $6 with new studs and grease....sounds like you need to crank the lugs a bit tighter too.. [img]images/graemlins/frown.gif[/img]
elusive is offline
post #5 of (permalink) Old 01-21-2003, 08:10 AM Thread Starter
Pog
Well I went this morning and took out the leftovers from my hub. I guess I was not clear enough with my q. I was wondering if the hub had to be removed I know the brake assembly had to be but was unsure if the stub would fit behind the hub. The one that was left did pull out fine so thats good. I always tight my wheels sufficently I double check each time. This is not the first time someone has done this, so I am thinking of getting another set of locks and having two on each wheel. Then I won't worry so much.. Thanks guys, oh yea dealer had to order studs and they complained because I didn't want their chrome covered nuts,,, they always screw up the cover breaks and strips the nut they suck so I passed and got aftermarket $20 for five nuts wow! [img]images/graemlins/cussing.gif[/img]
Pog is offline
