1 more coil voltage question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-01-2003, 09:16 AM Thread Starter
Journeyman
FNjeep's Avatar
thanks for bearing with me all, but this has been kicking the crap out of me. I was wondering how much voltage I should have at the neg. coil terminal in the run and start positions. I was also wondering if anyone knows of a link for jeeps of the sequence/systems to check for no-start conditions. I found one for another type vehicle when the search was down that said I should have voltage there but not how much.quick recap: 78 cj-5 w/304 "can" type coil. low voltage in run(6.5) but it does come up somewhat now in the start pos.(9-10) whereas it was dropping to 1.something, although it's very low on the neg. side.(mid 2s) the coil tested ok at the parts store, but i'm leaning towards picking up a new and mounting it in an upright position as this one has been mounted on it's side. the mod. also tested good, and yesterday I replaced the distributor with a rebuilt, new cap,rotor,plugs and wires but still no spark getting to plugs. thanx for all the help so far. Happy New Year, and hope everyones not feeling it too much today, specially after trying to follow this train wreck. Alex
FNjeep is offline
post #2 of (permalink) Old 01-01-2003, 11:37 AM
Re: 1 more coil voltage question
Do you have the prestolite or motorcraft system?
My 77 had the prestolite system and it was common to have the module go bad once or twice a year so I got a rebuilt point dist and switched it and I didn't notice a performance decrease. Plus its easy to carry a spare set of points and condenser in the glove box. I just had to add the resister to the + side of the coil. I've changed many a motorcraft module too.
I have found those module test not to be very accurate I've found many times they test good but still are the problem.
Are you testing the voltage with the wire on the - side or off?
the module may be taking voltage away if its hooked up. It should be close to the same voltage on both sides with nothing hooked to the - side. A resistance test is more accurate then a voltage test though.
Can type coil failures are rare I can count on 1 hand the number I have seen bad in 20+ years and a few of them were from a hole being worn in them from being mounted wrong.
Modules on the other hand are the cause of a no start 90% of the time and pickup coils/wiring the other 10% from my experiance anyway. If it was me I would run a ground wire from the batt. - to the module (a bad ground can fry them quick) and replace the module. I'd almost bet money thats your problem
in2mud is offline
post #3 of (permalink) Old 01-01-2003, 01:32 PM Thread Starter
Journeyman
FNjeep's Avatar
I have the motorcraft system. I got a new pick-up coil with the dist. also tried with a new module(the one that was in was bad, but my spare checked out ok) though I haven't spliced into it yet, i'm just trying to get it to start right now. when I checked for voltage on the -side everything was hooked up like it would be if i was going to run it (painless kit couple of green and a purple for tach? seems excessive but it's been like this without trouble for quite a while. Thanx for the info,Alex
FNjeep is offline
post #4 of (permalink) Old 01-01-2003, 03:38 PM
Official Historian
WILL's Avatar
It's not supposed to have full battery voltage in the run position.
WILL is offline
post #5 of (permalink) Old 01-01-2003, 04:12 PM
TFI and OEM Coils:
1. Full battery voltage in the Start postion.
2. About 8.4 to 8.7 volts in the Run position.
post #6 of (permalink) Old 01-02-2003, 10:45 AM Thread Starter
Journeyman
FNjeep's Avatar
thanks for the info so far guys, I touched on some of this in an earlier post, and I know I'm about 2 volts shy in both run and start, but my main concern now is the disparity in voltage on the neg. side of the coil. I'm only reading in the mid 2s in both positions and was wondering if this should throw up any red flags for me to check anything specifically.I'm planning on trying a new mod. and coil tomorrow, after I get one of those butane soldering irons to splice into the mod. I'm outdoors and don't want to run 100+ feet of extension cord for it.
FNjeep is offline
post #7 of (permalink) Old 01-02-2003, 02:08 PM
1. Don't worry about the negative side of the coil.
2. You don't have any control over it....
3. Until you undersand Kirchoff's law... the above statement don't make sense.
4. Remember that if the input voltage is low... the voltage at the other end of the coil will also be low...
5. So...
6. You're just gonna have to trust me. [img]images/graemlins/grin.gif[/img]
