- Jeep-Short Wheelbase
- - What breaks first ?? d35
(https://forums.off-road.com/jeep-short-wheelbase/148631-what-breaks-first-d35.html)
me and Andy (jeeper99xj) were talking about this.....hes seen two d35 blow the R&P....i've only seen one blown d35 and it was a shaft....so what breaks first usually...
pretend we have a 4 banger and 32" tires and 4.10 or 4.56 gears thanks! (this is not a discussion on the best axle...just what breaks first!!! [img]images/graemlins/grin.gif[/img] ) |
Re: What breaks first ?? d35
Other than online and mags, I have personally only seen broken axles in the d35. (and plenty of those) I didn't think the axles were even strong enough to kill the ring. [img]images/graemlins/blush.gif[/img]
I couldn't beleive Andy didn't kill his a long time ago. |
I rebuilt about 10 d35's in the past year or so. All but one rear were with stock tires. The biggest thing i saw fail were first the spiders would go and then the chunks of spiders would take out the r/p. But if i had to guess what will go first will be the axle. We see the r/p gone because when its that bad its sent to us. All of the other local shops can do axles. If i had a 10 bucks for every call for a d35 axle i would be sitting pretty.
1. axle 2. spiders 3. ring and pinion |
On mine the carrier cracked, which caused it to munch the spider gears.
I completely agree with Pontiac, but with one side note.
I realize the question specificaly stated axle ratios of 4.56 - 4.10, but just for the sake of presenting more information, the breakage I have seen most, when large tires are used with the 3.07 gears that came with the 4.0 HO, are busted pinion yokes. When I ran my d35 with 33x10.50 SX(for nearly 3 years), with a detroit locker and 4.56 gears I had only one axle shaft breakage. When I went to 35" SSRs, I started going through axle shafts like Rosie Odonnel through a box of chocolates. I never busted a R&P, but that may have a lot to do with running the Detroit. I have however seen dozens of chewed up D35 R&Ps at the Hammers. The Hammers are a great place to test just how tough different assemblies really are, since there are no by passes or turn arounds. The trails there will uaually find, that one spot where you have to push the limits to get through. |
My buddy has a '99 TJ with the stock 4cyl and 4.10's. [img]images/graemlins/AR15firing.gif[/img] He went through two or maybe three sets of spider gears. The last time he blew it up the carrier sheared in half, and his spider gears walked up his diff cover making some pretty holes. The R&P looked fine, and so did his axle shafts. He has since upgraded to a FF D60. He's running 31" BFG's, BTW.
User Alert System provided by
Advanced User Tagging (Pro) -
vBSecurity v2.2.2 (Pro) -
