SOA almost done - Need driveshafts - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-26-2002, 06:08 PM Thread Starter
86CJ7's Avatar
I have a CJ7 with JCWhitney 7 leaf rear CJ springs SOA. Both of my drive shafts are too short. The transfer case is a Dana 300.
Should I just get my shafts lengthened or should I look for a CV shaft?
Is there a shaft off another vehicle that might work that I could find in a junkyard?
Can you just replace half of the shaft? Like keep the end that connects to my differential and replace the side that connects to the Dana 300 with a CV?
86CJ7 is offline
post #2 of (permalink) Old 12-26-2002, 06:21 PM
Re: SOA almost done - Need driveshafts
if i were you i would do it right the first time and get a CV for the rear. I think tom woods driveshafts would be the best way to go, kinda pricey but worth it.
ClassicRockCJ is offline
post #3 of (permalink) Old 12-27-2002, 12:31 AM
Official Historian
WILL's Avatar
I disagree. If the stock driveshaft lengthened will work without vibrations, it is stronger than a CV driveshaft. Measure you angles and see if it will work first.
WILL is offline
post #4 of (permalink) Old 12-27-2002, 01:30 AM
Grapehead's Avatar
do a search for "waggy front driveshaft" i think, a few guys listed cv shafts from the fronts of other rigs that work.
Grapehead is offline
post #5 of (permalink) Old 12-27-2002, 09:48 AM
Pooh-Bah
pbmcauliffe's Avatar
I just lengthend my stock rear driveline after I had a few failures with cv shafts. I am running the same SOA configuration, have a T18, adapator and a D20 and have no vibration problems, no binding and no more concerns of breaking the cross pin.
pbmcauliffe is offline
post #6 of (permalink) Old 12-27-2002, 10:04 AM
you guys had cv failure, was it because the cv was set up properly??? if you want to lengthen your drive sahfts send them to me i will do it for $40 a shaft, email me if interested [email protected]
All i run are cv driveshafts they are stronger than stock if your set up right, a quadratrack front driveshaft is a great way to go but you will need to change your yoke.
MC
jeepsr4ever is offline
post #7 of (permalink) Old 12-27-2002, 10:24 AM
Pooh-Bah
Yes, my setup was correct and I still had problems with them. Usually breaking cross-pins or ball failure. Most of the people I wheel with would rather live with vibrations than run them. There has been a few posts on this bbs about cv failures.
I took a well known cv shaft out after it broke the second time, had my stock when lenghted &amp; changed the perch angle and it hasn't had a problem.
post #8 of (permalink) Old 12-27-2002, 10:56 AM
Official Historian
WILL's Avatar
Here's a post by H8:
I dont run CV shafts either. I went through 3 of them in about 6 weeks, when I 1st installed the 5.0. The centering balls on the H bar would weaken within a week or so (just, street driving) and the CV joint start ratteling like a couple of skeletons screwing in a metal trash can. The 1st one came apart and destroyed the CV, after that I would install the spare, as soon as the noise started. I finaly had a spare built without a CV, and bought a non CV yoke, so that I could do a trail run and not worry about it. There was actually less vibration, so I decided to keep it on full time and see how well the non CV shaft would hold up. I have never looked back, and have not had a shaft fail since. I get no bad vibration either, even on the highway at 70mph.
Jeff
89 YJ
(sensibly altered for occasional off road use)
Vision without Action, is a Daydream. Action without Vision is a Nightmare.
Jeffery Huelsman
89 YJ
WILL is offline
