-   -   CJ - Clocking a D300 - driveshaft mods needed? (https://forums.off-road.com/jeep-short-wheelbase/148097-cj-clocking-d300-driveshaft-mods-needed.html)
mark_louis 12-23-2002 04:11 PM
I've read several good posts on the subject but have not seen much mentioned about drivshafts. With between 3-4 in. of lift and the x-fer case just above the frame rail will my stock drive shafts work? If not what do you suggest?
Thanks
Mark
GP'n 12-23-2002 04:38 PM
Re: CJ - Clocking a D300 - driveshaft mods needed?
You will need to have a new one made, (Tom woods) comes to mind, or a local drive shaft shop can cut and install a new tube on yours. This is usually the least expensive. The best bet is to get it all done and then measure from flat to flat on the yokes. then measure your shaft. To do this compress the slip joint and then pull it out about 1.5" and then measure from center of the u-joint where it would sit on the yoke when installed. if this is the same your in luck if not have the new shaft made to fit these measurements.
mark_louis 12-25-2002 08:56 PM
Thanks for the response. I'll put it to good use. Hope your have'n a MERRY CHRISTMAS!
Mark
raymo 12-25-2002 09:52 PM
The rear shouldn't change due to clocking, but the front will. My CJ had a really small diameter driveshaft in front so I was glad it needed replacing.
I went to a dismantler that had over 100 driveshafts hanging from hooks. I found one that was a perfect fit, was in great shape, and was a larger diameter (was probably from the rear of some other vehicle). It cost $70.
jeepsr4ever 12-25-2002 10:28 PM
send me your old one and a measurement i will change the length for you $50
Email me if interested [email protected]
