Waggy CV front driveshaft for CJ-7 rear driveshaft - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-21-2002, 06:37 PM Thread Starter
Does anyone have any thoughts on cutting down a Waggy CV front driveshaft to use in the rear of a CJ-7?
I'm going SOA with Waggy D44's and I figure I will probably need a CV in the rear. The Waggy front driveshaft (from a QT) is skinny compared to the rear, but the slip joint size looks about the same as the rear (maybe a tad smaller). What is the torsional weak point in the driveshaft: Ujoints, tube, or slip joint? Would it bend easier than the larger tube shafts?
Will it be strong enough for 304/TH400/QT/4.56 D44's and 35" tires? Will the auto and full time case be more forgiving on the rear shaft?
I'd rather not mess with it if it won't last, but I have one and would use it if it will work.
JeepDaddy is offline
post #2 of (permalink) Old 12-22-2002, 09:02 AM
Official Historian
WILL's Avatar
Re: Waggy CV front driveshaft for CJ-7 rear driveshaft
If it is the 1-1/4" tube like the CJ QT uses in the front, I wouldn't do it. I had a new driveshaft made up 2 years ago. After a few trips, I noticed it was wobbling a little (transfer case and hubs unlocked so just the front shaft spun). I thought I had smacked it on a rock or something. I dropped it back off at the shop that built it to straighten it for me. He told me it wasn't bent from hitting something, it twisted. (check my profile for my jeep's equipment).
WILL is offline
post #3 of (permalink) Old 12-22-2002, 12:38 PM Thread Starter
It is the same diameter as my CJ QT shaft. 1 1/4" sounds right. I assume the tube wall is thicker to compensate for the smaller diamter.
post #4 of (permalink) Old 12-22-2002, 04:31 PM
Official Historian
WILL's Avatar
It should be 1/4" wall tubing. I don't know if the front being so long made it twist easier but I still would use 2" minimum in the rear.
WILL is offline
post #5 of (permalink) Old 12-22-2002, 07:46 PM
Grapehead's Avatar
just a thought, my 1988 ford ranger has a 2" cv front driveshaft that is a couple inches longer than my stock 85 cj7 rear driveshaft. you might want to try junkyards to find one like this. (i havent measured it's length but can if you like)
Grapehead is offline
post #6 of (permalink) Old 12-22-2002, 11:11 PM
I dont know the specs on the shaft but I am locked with a v8 and I used that shaft. Have had no problems so far with driveshafts, have broke axle shafts though. Mike
pbytrailz is offline
post #7 of (permalink) Old 12-22-2002, 11:56 PM
i used a mid 80s chevy front cv drive shaft for a manual and a np208 for my rear. these are pretty strong and are fairly common to find in the right length.
post #8 of (permalink) Old 12-23-2002, 08:21 AM
I used a front drive shaft from an 88 Jeep Cherokee. It's the same size as a stock rear CJ shaft. I had it cut down of course but it works great behind my t18. Just pick up a quadratrac front output yoke because you'll need to use that on the rear of the CJ .
Alec
Alec78CJ is offline
