Front diff. pinion seal - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-12-2002, 01:30 PM
I finally got the nut loose. Have new pinion seal. The parts store mentioned shims? Anybody have any info? Thanks Ralph P, New Jersey
post #2 of (permalink) Old 12-12-2002, 03:42 PM
Hank's Avatar
Re: Front diff. pinion seal
What are you working on?
Hank is offline
post #3 of (permalink) Old 12-12-2002, 03:54 PM
Thanks for your responce. 85 CJ 7 6 cyl 258. 4 Speed
post #4 of (permalink) Old 12-13-2002, 06:38 AM
Shims aren't involved in swapping the pinion seal. Pry the old one out. Put a film of oil on the new one and carefully tap it back in. Put the washer and nut back on and tighten til surrounding metal turns pink. Not really. Look up the spec, or get it from a dealer, and tighten the nut to it. That is rather important.
Jim_Lou is offline
post #5 of (permalink) Old 12-13-2002, 06:56 AM
Caver Dave's Avatar
You *can* add/remove shim from behind the outer pinion bearing if it's too tight/loose. When I changed my seal, the rear bearing was still flopping in the race. Since it doesn't affect the pinion depth, you'd be OK doing this. You'll have to SLOWLY remove the thin shims one at a time and re-torque the nut each timer though...PITA. Since it's the front axle, I "guesstimated" and stopped when I had about .005-.010" of wiggle in the rear bearing, replace the seal, and re-torqued. No problems after 5-6 pretty hard runs.
Caver Dave is offline
