electric fan - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-09-2002, 12:33 PM Thread Starter
electric fan
will a elec. fan cool a v8? (16 inch moves 2100 cfm.)
had a fan blade bent an no stroud an it never got before.but i was getting worried about the blade coming off so i tough i would try this i mounted it as a pusser instead of a puller. it said not to, but it sure opened the front of the moter up nice an if fit perfict in front.
started it up, let it get hot, tunred the fan on an it cooled right down, but it is only 40 degrees
duke
duke401 is offline
post #2 of (permalink) Old 12-09-2002, 01:05 PM
Re: electric fan
what does the weather get like in the summer? really hot? I know in ca, driving you would be fine, lots of air moving, but slow crawling on a trail I would guess that it would heat up. doesn't really hurt to try though, if it doesn't work, put the old setup back on (with a new fan of course)
surveyboy is offline
post #3 of (permalink) Old 12-09-2002, 04:31 PM Thread Starter
Re: electric fan
i didnt throw away the old one, just put way back in the corner. an yes it gets hot in kansas 30+ days over 100 this summer.but if you were crawling your engine is at low rpm an not pulling much air the fan is running wide open.
i am sure somebody has done this befor
duke
duke401 is offline
post #4 of (permalink) Old 12-09-2002, 06:04 PM
Re: electric fan
Well I have put one on my cj with a 258 and it has done very well. bumping around on the trails it stays on and keeps it cool. I have it hooked to a 3 way switch. on-off-themostat If i am going slow, i just flip it to on and keep it cool. should work for a v-8 with the right fan. btw, mine is a puller.
post #5 of (permalink) Old 12-10-2002, 06:29 AM
Re: electric fan
Duke,
I have done a double fan on my 360, one pusher on the rear right and a pusher on the front left with an adjustable thermo. Only problem I had was one day on the beach in deep sand, no breeze and hot(95-100). The fans were on constantly and my thermo housing malfunctioned/melted. Then it puked the coolant and overheated. I have since replaced the themo housing and things are back to normal for every day driving, but I still don't know if it was the thermo housing failure or the constant running of the fans that overheated the thermo housing that caused the overheating. Unfortunately I haven't been offroad in the same conditions since the problem. I'm still abit leary if I'm moving enough air cause the fans still run the majority of the time.
Pigpen is offline
post #6 of (permalink) Old 12-10-2002, 08:05 AM
Re: electric fan
I set up a buddies CJ5 that has a 304 with a pusher fan. When going slow off road he just leaves it run all the time and it hasn't overheated, it acually runs cooler then it did before.
in2mud is offline
