lift problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-25-2002, 12:44 PM
CRSETH
lift problem
This past weekend I helped a friend put on a spring and shackle lift on his 79 CJ-5. I dont know how much lift the springs were but the shackles measured 6" eye to eye. Everything went good on the install until we got to the front right side. The U-bolts do not align with the front axle they are at an slight angle. The shackle is also turning to the inside. How can I get all this to line up? There is a slight vibration in the driveline now, what parts are in a t-case lowering kit and can I do it without buying a kit? [img]images/graemlins/confused.gif[/img]
post #2 of (permalink) Old 11-25-2002, 01:00 PM
Re: lift problem
6in shackle? Jesh! Anyone else think thats alittle big? You could order a xfer case lowering kit to reduce the angle and vibes. [img]images/graemlins/smirk.gif[/img]
post #3 of (permalink) Old 11-25-2002, 02:34 PM
Re: lift problem
I made my own T-case lowering kit for my CJ-5. I made some spacers from some solid stock. I think they are about 1" or less. As far as I know all the kit does is lower the T-case mounting to lessen the angle on the driveshaft. Dont forget about the pinion angle. Did you use any pinion angle shims? Could you explain how the u-bolts are not lining up a little better, maybe some pics? Are the spring pads lining up with the springs? Are the spring and shackle hangers straight and lined up? A little more info might be helpful.
itsaposcj5 is offline
post #4 of (permalink) Old 11-25-2002, 03:03 PM
mbalbritton's Avatar
Re: lift problem
6" long shackles? that's 1.5" shackle lift. Not unheard of, but longer than I'd personally go. I hope they are "H" Shackles!
brent
mbalbritton is offline
post #5 of (permalink) Old 11-25-2002, 03:41 PM
Re: lift problem
Put all the lift parts on hand tight and line it all up Before you tighen it down, if there is a stock track bar or sway bar, get rid of it.
Put on some shorter shackles(IMO, 4" max) and see If the vib goes away.
(It will handle better also)
If not, buy an angle finder and check the rear axle pinion angle compared to the Tcase output angle, they need to be very close to the same. If they are not, you need to shim or cut and reweld the axle's spring perchs so get the pinion angle is 2 degree less(down) then the Tcase output angle. You want the pinion angle a little less to compensate for spring wrap.
The Tcase drop is a last resort deal, it just defeats part of the reason of a lift, ground clearance. If the angles are right and the lift is less then 4" you can fix it, with a 4"+ lift you may need a CV shaft.
W.C. is offline
post #6 of (permalink) Old 11-26-2002, 06:52 AM
CRSETH
Re: lift problem
Thanks for the info on the T-case lowering thats what I thought also. I didn't use any shims or check the angles. The spring pack and the shackle hangers line up somewhat. I'll check all the angles out this weekend and get back to you all.
