can I pressure test my F.I. lines? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-25-2002, 06:21 AM Thread Starter
RickB's Avatar
I am doing a 4.0 swap into my 1980 CJ7, and want to somehow pressure test my fuel lines for the fuel injection. I have all the lines hooked up. Can I just jumper the electric pump to the battery and pressurize the lines to check for leaks and loose hoses? I'm using a in-line pump.
RickB is offline
post #2 of (permalink) Old 11-25-2002, 07:26 AM
Re: can I pressure test my F.I. lines?
Yes.
Tip: Release the air from the fuel rail by pressing in on the schrader valve on the rail. Hold a rag over it when doing it so you don't get squirted!
Use safety glasses.
Jaffer is offline
post #3 of (permalink) Old 11-25-2002, 08:44 AM
Tippy's Avatar
Yes. Cycle the pump, push on the schrader valve like jaffer said, then repeat. The first couple of times you may just get a bit of air out of the valve before the fuel makes it all the way into the rail. I also put an in-line preasure gauge so I could see if my pump was working correctly. I used two hose clamps at each hose/steel connection and haven't had any leaks.
Tippy is offline
