New body tub... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-10-1999, 12:04 AM
New body tub...
My CJ needs a new body.[img]/wwwthreads_images/icons/frown.gif[/img] I can't decide between fiberglass or metal. Fiberglass won't rust, but it cracks. Metal doesn't crack and has a bit more "give", but it rusts. Living in Michigan, I'm not sure what impact the cold would have on the fiberglass, but I know what impact the salt has on metal [img]/wwwthreads_images/icons/crazy.gif[/img].
So... I'm looking for opinions from those that have fiberglass and/or new metal tubs. Thanks.
post #2 of (permalink) Old 10-10-1999, 01:11 AM
Re: New body tub...
I just recently replaced the tub on my 79 CJ7 with a metal tub that I picked up at a salvage yard, luckily it had no rust and came off a california car so I did luck out. I did look into a fiberglass tub but with the total cost for the tub, windshield frame and tailgate plus the attachment kits and shipping the cost came to about $2750.00 (4 wheel drive hardware). So, I went with the metal.
Also, I have a bit of a bone-headed purist view in that I figured if I was going to a go to all the work with a ground up rebuild then by god I was going to go with the metal tub.
Maybe this is not the most rational decision and I know a bunch of folks who love their glass tubs but like I said I'm a bit bone-headed. Hope this helps
You could also ask CJDave. In my mind he's TOPS. My wife has even begun to ask "Who is this dave guy?" The man is truely a wizard with all things mechanical and one hell of a nice guy.
all the best
sean
post #3 of (permalink) Old 10-10-1999, 03:29 AM
Re: New body tub...
[img]/wwwthreads_images/icons/wink.gif[/img] You know, there are some darn good body protection coatings now that can be installed, and as long as the body was off, and especially if it were new, you could really spend the time and get a super surface on the critical areas. You could also move to Phoenix Arizona, I hear it doesn't rain much there and stuff lasts a long time. If I am not mistaken, I think the JAFFER did a dual-coat tub treatment...if it wasn't JAF, then it was someone else. You are bound to get some responses to this post which will help, but my money would be with the steel tub and an extensive protection coating.[img]/wwwthreads_images/icons/crazy.gif[/img][img]/wwwthreads_images/icons/cool.gif[/img]
CJDave
CJDave is offline
post #4 of (permalink) Old 10-10-1999, 06:57 AM
LooseNut's Avatar
Re: New body tub...
Well......Not to go against CJDave, but I too am in Michigan, and if you go with the Steel tub you'll probably be fixing rust on it in a few years. That is if you drive it on the road in the winter (that's what Jeeps are for). They just flex too much and there are too many little cracks and crevaces that can get salt in them and start that old rust problem. I just loved it when every Jeep I ever owned started to bubble up at the seams between the rear corners and side panels. My money is with the 4WD Hardware body. A tub from them is $1200.00 vs. a used steel tub for $800.00. Then you'll still need a new front end whichever way you go, not to mention a windshield frame and all new hardware.
Where are you in Michigan? I'm in Onsted. I know of a guy in Chelsea who (a year ago) had a '90 or '91 Wrangler tub fo $800.00. Email me and I can give you his name and number. Oh....it had a little bit of rust on it where the floor and side panel are joined.
Loose nut behind the wheel
Another right-wing conservative.....
LooseNut is offline
post #5 of (permalink) Old 10-10-1999, 09:01 AM
Re: New body tub...
I'm a bit leary about using a used tub since you never know what condition those seams are in (plus they're hard to find). I was going to buy a new tub whichever way I went. Why would I need a new front end? That's the best part of this jeep [img]/wwwthreads_images/icons/laugh.gif[/img]. A windshield frame I can see... that's going [img]/wwwthreads_images/icons/tongue.gif[/img]
I'm in Southgate - go all the way east from Onsted then a little north (South of Detroit). I'm not really interested in a Wrangler tub though, I think it would clash with the CJ stuff [img]/wwwthreads_images/icons/smile.gif[/img]. I appreciate the offer and thanks for the advice.
post #6 of (permalink) Old 10-10-1999, 09:08 AM
Re: New body tub...
Well, I think moving is out of the question, but I'll check with my wife [img]/wwwthreads_images/icons/laugh.gif[/img]
Have you done a new tub? Treatment sound good, but the Michigan winter salt tends to eat things. I'm more concerned about durability. If you hit something with a metal tub, it'll bend (and probably scratch and rust). If you hit something with a fiberglass tub, it'll crack (maybe? depends how hard you hit). Now, which is easier to fix, a bend (and paint and/or rust) or a crack (if it cracks).
Then, there's the twist factor [img]/wwwthreads_images/icons/crazy.gif[/img] Decisions, decisions....
post #7 of (permalink) Old 10-10-1999, 10:01 AM
Re: New body tub...
[img]/wwwthreads_images/icons/wink.gif[/img] You know, this might be a good question to ask BigMan, he has a CJ7 and did the fiberglass tub thing. He bought the tub without the tailgate. Go to his web page and check it out. I got my rear taillight mounted flush first from him, then someone else said to cut them into the rear panel high to get into the interior. We are considering that very thing. BigMan has a tip on the rear light thing on his page too.[img]/wwwthreads_images/icons/crazy.gif[/img] check it out.[img]/wwwthreads_images/icons/smile.gif[/img]
CJDave
CJDave is offline
post #8 of (permalink) Old 10-10-1999, 10:03 AM
Re: New body tub...
I'd have to agree with cjDave on this one. There are so many different types of coatings out there that you can use to prevent rust. I think its overland willys that will do a special rust preventive on there tubs when you purchase one. Also, if you buy one new, I would take it to someone, turn it upside down on the trailer and have them spray it on the underneath side with a good polyurathane coating while they could get to all the holes and cracks. Metal would definitly be my choice! Steve
Mopar360yj
87yj+20,74CHR.030360,SOA,35BFGATs,46RH,241DHD,
D60-44-4.10
post #9 of (permalink) Old 10-10-1999, 10:20 AM
Official Curmudgeon
CJ7Taz's Avatar
Re: New body tub...
Fiberglass! No two ways about it.
I did my CJ7 about four years ago using an AJ's tub and one piece front end. It's quieter and even
warmer in the winter. The one piece front end is great when it comes time to work on the engine. I can
even change oil without getting under it.
Now if I could just find a carbon fiber frame...
CJ7Taz is offline
post #10 of (permalink) Old 10-10-1999, 10:54 AM
Re: New body tub...
Do you have a CJ7 or a 5? i have a 5 that i am trying to sell in order to buy a 3b, and it has a brand new steel tub, front fenders, hood, windshield frame and windshield. I would be willing to part it out...heres a pic too.
JeepersCreepers is offline
