4.0 swap and check engine light - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-21-2002, 09:27 PM Thread Starter
Tippy's Avatar
Ok, I've got another check engine light question. When I put the 4.0 head and EFI on my CJ, I put a small cel in my dash. I'ts never worked. The light is good, I just took it out and tested it. The power conection from the computer and the ground conection seems to be good. Will the cel only blink if there is a problem, or should it come on when I turn on the key until the motor starts, and should it come on if the engine dies? I've tried the on/off 3x trick, but it still doesn't work. It's the only mystery left for me to figure out on the swap!
Tippy is offline
post #2 of (permalink) Old 11-21-2002, 09:35 PM
Re: 4.0 swap and check engine light
One side of the light is switched power, the p.c.m. controlls the ground.
dorfs is offline
post #3 of (permalink) Old 11-21-2002, 09:47 PM Thread Starter
Tippy's Avatar
Ah, that explains it! I've got both wires grounded! I need to put the other wire of the ligt to switched power like on one of my gauges!
Thanks!
Tippy is offline
post #4 of (permalink) Old 11-22-2002, 12:12 PM Thread Starter
Tippy's Avatar
Yep, that got it going, although now it won't shut off. I did the test and it show 33 and 76. I think this is what it shows, I tested it 3 times and came up with close, but different numbers each time (I just can't cout that fast!) That means that the air cond. relay is not working (33 - no big deal, no way to fix without a/c) and that my fuel pump resistor bypass relay is not working (76). How do I fix the later and could this be why I have had such bad trouble with my fuel pumps?
Tippy is offline
