How to fasten rubber to steel? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-18-2002, 07:55 PM Thread Starter
The axel bump stop rubbers are perfect, but the steel plate they're bonded to is almost totally rusted away. Does anybody know how to bond the rubber to a new piece of steel? Maybe a bunch of short sheetmetal screws?
It's not that I'm cheap - I'm really, REALLY cheap. Besides, like I said, the rubber is perfect. And original.
Jim_Lou is offline
post #2 of (permalink) Old 11-18-2002, 08:01 PM
Re: How to fasten rubber to steel?
What I have found will glue anything to anything is an adhesive called Lexall. It's clear, comes in a tube, and I seriously think it would glue a blob of grease to teflon. [img]images/graemlins/grin.gif[/img]
post #3 of (permalink) Old 11-18-2002, 08:05 PM
Carpal \'Tunnel
knifeboy2's Avatar
JB Weld can do wonders. I've filled holes, drilled, and then tapped it. It will hold and its tough!
knifeboy2 is offline
post #4 of (permalink) Old 11-18-2002, 11:18 PM
Barge Cement. I've never had it fail. I've glued rubber to bare steel, chrome, and aluminum, alot. I always keep a tube or two around. (good for many other materials, too.)
"Barge" is the brand name.
javajeeper is offline
post #5 of (permalink) Old 11-19-2002, 09:16 AM
kutyafal's Avatar
Where can you get Lexall ?
kutyafal is offline
post #6 of (permalink) Old 11-19-2002, 07:21 PM
I Do This For The Glory
JEEPN's Avatar
Liquid Nails, it'll adhere anything to anything. I made the mistake of using it to "seal" between 2 pieces of metal, and they are now permanent.
JEEPN is offline
post #7 of (permalink) Old 11-19-2002, 09:30 PM
I got it at a local hardware store. The stuff is clear and comes in a clear tube, and it is flexible, but strong.
post #8 of (permalink) Old 11-19-2002, 09:53 PM
i would drill a one inch hole about 1/2 inch into it then finish it with a 1/4 inch hole all the way through it and use a 1/4 inch bolt with a washer on it
3jeepguy is offline
post #9 of (permalink) Old 11-19-2002, 10:31 PM
Oops. It's LEXEL, not lexall.
http://www.sashcosealants.com/products/lexel.shtml
post #10 of (permalink) Old 11-20-2002, 07:34 AM Thread Starter
Lexel! No wonder I couldn't find Lexall cement. I've used it before. Pricey but good. I have some I'd forgotten about on the shelf. Also found a source for Barge Multipurpose cement. I think I'll get a small tube of that and test both. If I get any noteworthy results I'll post them.
Thanks everybody.
Jim_Lou is offline
