U Joints are a pain - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-18-2002, 06:02 PM
U Joints are a pain
Ok I've been trying to get a U joint out from my rear driveshaft and it won't budge... I got the straps off and the two retaining clips... I used a hammer with a Small Socket on top and a Larger Socket on the Bottom to try to get the Cap to go through... didnt work. Just got a big C- Clamp with same setup didnt work. Sprayed it with some PB blaster... doesnt help. Anyone have any trick? Or Ideas? PLEASE [img]images/graemlins/confused.gif[/img]
post #2 of (permalink) Old 11-18-2002, 06:25 PM
I Do This For The Glory
JEEPN's Avatar
Re: U Joints are a pain
Yes, set the driveshaft in a vise, so the free ends of the U-joint are supported by the vise. Now hit the driveshaft at the base but on the yoke (strongest part). The shaft will travel down while the u-joint stays in the same plece.
Or you can cut the u-joint in half, using a cross pattern and smack the individual ends out.
Either way, add some PB Blaster and/or a little heat and it should come out. I've never seen a joint I couldn't change, it took me 8 hours once to change out a pair, but they came out.
JEEPN is offline
post #3 of (permalink) Old 11-18-2002, 06:44 PM
elusive's Avatar
cutting torch makes quick work of the really PITA ones... try getting the chevy u-joints out.. the ones that are glued in....
elusive is offline
post #4 of (permalink) Old 11-18-2002, 08:05 PM
I use a vise, but not like JEEPN said. I just squeeze them out, use 2 sockets like you would beat it out with, only squeeze it out with a big vice. Works every time. BTW, use impact sockets.
post #5 of (permalink) Old 11-18-2002, 08:58 PM
Got any buddies with hydraulic presses? They're a lifesaver in such situations. I replaced mine last week, but i've got a hydraulic and an arbor press on hand and it takes me all of 15 minutes for the whole procedure from removal to installation.
SuburbanAssault is offline
post #6 of (permalink) Old 11-18-2002, 09:07 PM
The only thing you need to worry about with a press is bending the ears of the yoke. You have more control using a big vise.
post #7 of (permalink) Old 11-18-2002, 09:33 PM
Really? I do the same technique as the vise witht he 2 sockets, just got a lot more pushing it. I've never had problems before, but I'm sure I could be wrong... [img]images/graemlins/smirk.gif[/img]
post #8 of (permalink) Old 11-18-2002, 11:17 PM
Caver Dave's Avatar
I watched a guy use an air hammer (he called it the "burp gun")to knock out some stubborn ujoints. In fact, it took longer to hook up the air to it, than remove the joints. He used the same technique for installing the replacements. Just used a little less pressure.
Caver Dave is offline
post #9 of (permalink) Old 11-18-2002, 11:23 PM
Whats the process to put it back together? Put on the straps and put on the Caps on the other two ends then the Retainer? I'm going to get ahold of a torch tomorrow and try to heat them up and knock it out. [img]images/graemlins/smirk.gif[/img]
post #10 of (permalink) Old 11-19-2002, 03:53 AM
I dont want to hear anybody bitch about u-joints being hard to replace, ask wades76cj7 about his killer u-joints and my face= 11 stitches and a scar!
lumpy85 is offline
