-   -   Weber float bowl empty again. (https://forums.off-road.com/jeep-short-wheelbase/1438-weber-float-bowl-empty-again.html)
LooseNut 10-09-1999 02:51 PM
I had a chance to start my Jeep ('84 CJ7 w/ Weber 32/36) this morning after sitting for a week. Guess what.....float bowl was empty and had to crank it for about a minute before it would start. I disconnected the fuel return line from the filter a couple of weeks age. That apparently didn't fix the empty float bowl syndrone. I'm going to plug off the float bowl vent next to see if that helps.
Loose nut behind the wheel
Another right-wing conservative.....
**DONOTDELETE** 10-09-1999 09:19 PM
Re: Weber float bowl empty again.
I remember having a little back and forth on this a while ago, I was having the same problem, although it may not be to the degree you are having it. But, I started parking my Jeep in the garage (finally cleaned out the garage!) a while ago, haven't had the problem since, one pump, 2 at most, even after a few days. I think my problem may have been due mostly to evaporation in the intense NM sun along with very low humidity.
Brad (from the 4 Wheeling center of the universe, 4 corners USA)
LooseNut 10-10-1999 07:07 AM
I'm inclined to think it's evaporation, too. Before I had my Jeep on the road, I remember noticing the smell of gas around the engine compartment when I was putting on the front fenders or working on the clutch linkage. I checked all the hoses for leaks and found nothing. The smell seemed to be from around the air cleaner. I've always parked mine in-doors out of the sun, and it's always been hard to start after 2 or 3 days. Once it pumps up it purrs like a kitten.
