360 vacum lines - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-16-2002, 02:19 AM Thread Starter
360 vacum lines
I am finally gettin around to pulling the 360 an d am wondering what to do with the vacum lines. I have never workered on a vehichle smog equiped. SHould I pull all of them , plugg all of them, bypass some? HWat to do?
Thanks,
tony
tonyscj5 is offline
post #2 of (permalink) Old 11-16-2002, 11:47 AM
Re: 360 vacum lines
I stongly suggest you look at a vacuum line diagram for your year of motor. A lot of those lines just run smog equipment which you may or may not be able to remove and have it run right, and some of them are totally necessary, such as vacuum advance for a distributor. Don't just start pulling them! [img]images/graemlins/shocked.gif[/img]
post #3 of (permalink) Old 11-17-2002, 02:54 PM Thread Starter
Re: 360 vacum lines
I am looking at the vacum diagram, but still not sure what is nessecary to keep the engine running. I need the distrib advance, what about EGR, VSD and PCV valves? What about the check valve? What about spark CTO switch? EGR CTO switch? diverter valve? Purge valve signal? Should I just remove the charcoal canister, then fallow the lines going to it and plug them? Any advice will help, I dont have much expirience or understanding about smog equipment.
Thanks very much
Tony
tonyscj5 is offline
post #4 of (permalink) Old 11-18-2002, 01:35 AM Thread Starter
Re: 360 vacum lines
btt
tonyscj5 is offline
post #5 of (permalink) Old 11-18-2002, 09:57 AM
Re: 360 vacum lines
vac advance, PCV, thats all thats a MUST HAVE.
everythying else has been removed from mine
ozarkjeep is offline
post #6 of (permalink) Old 11-18-2002, 06:07 PM Thread Starter
Re: 360 vacum lines
can I remove the other lines? or plug them?
thanks
tony
tonyscj5 is offline
post #7 of (permalink) Old 11-18-2002, 06:37 PM
Re: 360 vacum lines
My EGR woundt sela off, so it was welded shut, but I think you could remove the vac line and it should seal unless its defective.
the vac canister isnt really a must have, but you do need to determine whiuch is the fuel return, its the 3rd leg of the fuel filter on mine) and also some 360s have a bowl vent that went to the vac canister.
any other vac sources on the manifold can be plugged.
post #8 of (permalink) Old 11-18-2002, 11:20 PM Thread Starter
Re: 360 vacum lines
So.... Just to be sure I have this straight, I need to keep PCV and vac advance hooked up, disconect the rest, What about the bowl vent, this would be a line running from the carb to the canister? What should I do with this when I remove the vent?
Thanks for all your help,
not sure what I would do with out you all.
Tony
tonyscj5 is offline
