MM Winch- want to buy - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-13-2002, 11:39 PM Thread Starter
Can anyone tell me a good online vendor for the Mile Marker winches? Also, what is the Power In/Out feature on the MM 75 models? Is it worth the extra $?
Thanks, OS
OregonSahara is offline
post #2 of (permalink) Old 11-14-2002, 12:25 AM
muddybronco's Avatar
Re: MM Winch- want to buy
http://www.winchesplus.com
I too have been trying to figure out the difference between the 70 and 75 series packages... it appears that with the 70 you just get the winch and fairlead, and you have to supply your own 3-way Hydro solenoid block, remote, hoses, fittings, and wiring. To save hassle, I would (and am going to) get the 75 series with the proper vehicle P/S pump adapter parts and be done with it. You might save a little by buying the hoses/solenoid separately but it's not worth the hassle. I think power in/out just refers to how the winch operates, but it's not exclusive to the 75-series so dont worry about it. Good luck, you have chosen wisely [img]images/graemlins/cool.gif[/img]
muddybronco is offline
post #3 of (permalink) Old 11-14-2002, 11:16 PM Thread Starter
Thanks for the info. I just received the following email from MM. This seems to clarify the differences in detail.
"The difference between the 70 and the 75 series winch is in the placement of
the valve. The 70 series winch uses a remotely installed valve ( under the
hood of the vehicle), and the 75 series winch has the valve installed on the
winch body itself. We recommend the use of the 75 series winch in most
cases, as it is easier to install. The 70 series winch is used when you
want to use a receiver mount in the front or rear of your vehicle, and
in certain tight applications where there might be a clearance problem. The
75 series winch comes complete with everything except the vehicle adapter
kit ( the connections to your power steering pump and power steering box).
The 70 series winch needs a valve adapter kit that is specific for you
vehicle. They operate identically after installation, they both have power
in/out.
To mount the 75 series winch on a Wrangler, you need to use our winch
mounting plate, as the valve hits the radiator using any other manufacturers
mount. If you have a mount made by another manufacturer, you need to use
our 70 series winch."
-OS
