44 spindle interchange ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-13-2002, 05:28 PM
Ok I was planning on getting the mid-70's Chevy Knuckles, spindles, and brakes to go on a waggy 44 with ford rotors for 5x5.5.
I was going to try to get them to split the knuckles and out on the 44 for me so I could just buy the housing and shafts. Well they won't break it apart for me so my question is:
Will the spindles for the wagoneer work with the chevy knuckles and ford rotors? If so do they use the same inner and outer bearings as the chevy/ford combo does?
post #2 of (permalink) Old 11-13-2002, 05:52 PM
jeepgod's Avatar
Re: 44 spindle interchange ?
they do not use the same inner bearing.. same outer.. yes.. but you can take those spindles to a machine shop and have them turned down to fit the inner ford bearings.. should be about $40.. for both of them.. ball park figure
jeepgod is offline
post #3 of (permalink) Old 11-13-2002, 08:01 PM
Tippy's Avatar
You can use waggy spindles if they are from '74-'76. These spindles should have the 1.7812 id that you need for the ford hubs and rotors. I got a '76 axle form a waggie so that way I have both the correct spindle and the flat top knuckle for the high steering. Or you can get new spindles spicer part number 706528x.
Tippy is offline
post #4 of (permalink) Old 11-14-2002, 01:59 AM
I have a set of the spindles that work with the ford hubs (came off a '75 wagoneer). I am planning listing them on ebay, but would sell them for $75/both. The local junk yards around here are getting $50 per side if you can believe it.
I also have a set of the flat top knuckles that I am also going to list on ebay, but would sell for the $75.
raymo is offline
post #5 of (permalink) Old 11-14-2002, 10:22 AM
Ok, from what you guys have said then and from reading on your site jeepgod....I should be able to use the 89 wagoneer brake calipers and backing plates with the chevy flat tops and the smaller outside diameter spindle from a chevy or a 74-76 waggy?
If so that will be good cause then I can use the brakes that are on the axle I am considering and all I have to do is get different spindles or have them turned down combined with flat tops and ford rotors and hubs.
Thanks for being patient with me guys I just don't want to buy anything twice or parts that I don't need. Hard to keep straight all the things that are interchangable from year to year but I am learning thanks to this board
