14 bolt w/37"'s and other GM full width questions - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-13-2002, 02:07 PM Thread Starter
Pooh-Bah
pbmcauliffe's Avatar
14 bolt w/37\"\'s and other GM full width questions
I am thinking of running full width axles (GM style, not FSJ style) and came across a deal on a 3/4 ton Dana 44 69" front, and 14 bolt 67" rear
In searching most say to run at least 38" or taller tires, anyone ever run a shaved 14 bolt and 37"'s? I have a new set on 37" MT/R's and would prefer to not have to buy new tires as well, I will grind the calipers to run a 8-lug 15" rim.
I am guessing it would be around 81" wide front, and 79" wide rear (with 15x8 4" bs, 12.50" tires) anyone know for sure, my trailer is only 82" wide and I would like to be able to drive onto it [img]images/graemlins/laugh.gif[/img]
The rig is not a DD, so legality isn't a real big issue for width and the whole tire being outside the tub.
pbmcauliffe is offline
post #2 of (permalink) Old 11-13-2002, 02:30 PM
Re: 14 bolt w/37\"\'s and other GM full width questions
You can run what ever tire size you want it is just a matter of how much ground clearence you want. Keep in mind true tire size also. my brothers setup was 14 bolt 38inch tsl's which were really 37inch and my setup was a d44 with q78's measured 35 inches tall.
When I sold my 44 and bought his 14 bolt and wheels I lost 1/4 of an inch (and he already had it shaved)
A 44 is a comon axle and with your tires which probally measure a 36, then you would be 3/4 of inch below a 44 setup. So I would just use your tires, when they wear out you can go bigger if you want. Mike
pbytrailz is offline
post #3 of (permalink) Old 11-13-2002, 04:04 PM
Can we get some pics of your brothers shaved 14 bolt... I wanna shave mine but not all the way where I have to weld a plate onto the bottom..
toddw is offline
post #4 of (permalink) Old 11-13-2002, 06:50 PM
you'll definately need to shave it. i like my 14bolt but then again i run 42's
post #5 of (permalink) Old 11-13-2002, 07:19 PM
Old pic of shaved 14 bolt (about 1.25" shaved) with those little 37s [img]images/graemlins/grin.gif[/img]
Had about 10" under the diff
W.C. is offline
post #6 of (permalink) Old 11-13-2002, 09:38 PM
looks like you'll be spending 2+ hours with the grinder then [img]images/graemlins/crazy.gif[/img] Have fun [img]images/graemlins/tongue.gif[/img]
post #7 of (permalink) Old 11-13-2002, 09:56 PM
WC- Those hummer radials??
I`m gonna be running the Hummer Bias Plys until I can afford my 38" SX and they are only 36" so I`ll be lower than that... gotta shave for sure.. got any pics of it shaved??
Did you shave just the lip or into the housing more where u had to weld a plate on it ??
Thanks
toddw is offline
post #8 of (permalink) Old 11-14-2002, 10:18 AM
Yes , those are the radials.
Just cut the extra material off the housing, not though the housing.
Used a skillsaw with a metal cutting blade and then a 4" grinder, took about 20 minutes to cut, grind and paint (BustedRig,,,have you ever done this before?? 2+ hours?? [img]images/graemlins/crazy.gif[/img] )
W.C. is offline
post #9 of (permalink) Old 11-14-2002, 05:48 PM
I got an older style pre finned 14 bolt with the lip that's about 1.5 inches, using only a grinder it takes a long fawking time to remove 1" of cast housing.
post #10 of (permalink) Old 11-14-2002, 09:54 PM
I guess it would with just a grinder,,,,,,,,,,,
This is after the frist cut with the skillsaw,,,, used the grinder for the rest.
W.C. is offline
