I knew this day would come. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-13-2002, 07:42 AM Thread Starter
I knew it was only a matter of time until I was going to have somthing go wrong where I wasn't comferdable working on it. To this point in my Jeep life I have been lucky enough that I have never had to break into the engine. I have worked on the engine on the outside, but never gotten into the inside.
Well the AMC 360 has developed a tick. I get a ticking noise when the engine is under load. When the load is gone, like at idel there is no tick. From the sound of it it is coming from the top of the motor. Valve problem I am guessing, because those are the only things that move up there. How is the best way to trouble shoot this noise and figure out what it is. And then the next step will be to figure out how to fix it.. if need be. I have heard of people who have ticking engines that run just fine. Any help or advise on this subject would be great, like I said, I have never had any experence working on the inside of an engine.
Olin18 is offline
post #2 of (permalink) Old 11-13-2002, 08:13 AM
Re: I knew this day would come.
There's nothing in the valve train that is load sensitive. The good news is that this is the classic description of an exhaust leak at the manifold. Except that usually they are audible at idle - just a lot less noticible.
Take a flashlight and some dental mirrors and look carefully at each joint between the head and the manifold. You should be able to see some signs of exhaust leakage.
Jim_Lou is offline
post #3 of (permalink) Old 11-13-2002, 09:00 AM
Official Curmudgeon
CJ7Taz's Avatar
Also open the hood with the engine running in the dark and look for stray sparks from the ignition. Because higher RPM gives higher oil pressure, valve train noises tend to be more noticeable at idle. Since yours is the opposite, I'd be looking elsewhere.
CJ7Taz is offline
post #4 of (permalink) Old 11-13-2002, 10:50 AM
Official Historian
WILL's Avatar
Or another way to 'look' for exhaust leaks is to move your hand around the manifolds during the first few minutes the engine is running and the manifolds are still cool enough to touch. You'll feel the air leak.
WILL is offline
post #5 of (permalink) Old 11-13-2002, 11:21 AM Thread Starter
Thanks for the input, that is a load off to know that the valves will make noise all the time. With my problem there is a serious difference in volume as rpms go up. I can live with an exhaust leak, I will try to those ideas to find where my problem is, thanks.
Olin18 is offline
