-   -   Hockey-puck lift question (https://forums.off-road.com/jeep-short-wheelbase/143340-hockey-puck-lift-question.html)
**DONOTDELETE** 11-13-2002 06:32 AM
I ran into a couple of articles on the Net about 1" hockey-puck lift. The main problem was that, allegedly, the puck is not flexible, so it will eventually break into 1000 pieces, rather then distorting itself (like regular body mounts/lifts). Does anybody have any experience with hockey-puck lift?
Also, I read that the radiator should be lowered, and the front brakeline too. Is that true, is that a problem to do? What happens to the clutch linkage, driveshaft angle, etc? Or don't they suffer that much?
And as we talk about pucks... I have been given an (good) idea about cutting two pucks in half (over the diameter), and using those four halfs as bumpstops. Is it going to work, or are they too stiff? Or too small? Diameter of the puck is 3", so the BS's should be 1.5" each. But my main concern is wil they, when hit by the axle, break in 100 pieces, or are they going to be too stiff to use as bumpstops?
Thanx!
Jim_Lou 11-13-2002 07:20 AM
Re: Hockey-puck lift question
IMHO hockey pucks are too hard for either application, even if they don't shatter.
Used as a body mount, they will make the body flex because the puck won't. Pretty soon you'll get fatigue cracks.
Used as a bump stop, they'll transfer the impact into the frame and axel, instead of giving the contact a soft stop.
Lots of people have used them as body mounts over the years, but I doubt that the long term results are good. Now, if you were to use the puck just as a spacer, with a regular rubber body mount on top of it, that should be OK. Be sure to put the puck against the frame, not against the body.
**DONOTDELETE** 11-13-2002 07:33 AM
Yes, I am. I'm not planning to "loose" any existing parts... Just to add that "puck-spacer" on the existing rubber mounts. So, I should put the puck-spacer on the bottom (the rail mount), then the rubber on top of it, and then the body?
Jim_Lou 11-13-2002 07:41 AM
That's the way I'd do it - put the puck between the frame and a stock rubber mount. I don't see how it could cause any harm there, as long as it doesn't break.
**DONOTDELETE** 11-13-2002 07:49 AM
I see...
And do you know anything about those other things (brakelines, clutch linkage, driveshaft, radiator)?
Jim_Lou 11-13-2002 08:02 AM
Well, let's see. The brakelines run from the master cylinder, which is mounted on the body, to the proportioning valve, which is mounted on the frame. When the body and frame move farther apart, those lines will have to be longer. Typically, they have two or three loops for stress and vibration isolation, so you might be able to stretch them. I don't know if that is safe or not.
If you don't have hydraulic clutch linkage, you have a bellcrank mounted between the frame rail and the bellhousing. It will be OK, but the pushrod from the pedal to the bellcrank will need to be lengthened.
The driveshafts won't be affected as both the transfer case and axels are mounted to the frame. They don't move even if you take the body off.
If you have a shroud around the radiator, when the body moves up, the fan is likely to hit the bottom of the shroud. Dropping the radiator and its shroud by the amount of the lift will probably be a good idea. I don't think that should be difficult - just drill a new set of holes in the body where the radiator bolts up.
You might also have to get longer hoses from the gas cap to the tank.
If you only lift the body an inch, I think everything else will reach.
