HELP ME PEOPLE! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-10-2002, 05:11 PM
HELP ME PEOPLE!
Alright offroading today in the Wrangler... got alittle to deep... well the Air Intake Tube fell off the Air Box at some point in the day so all the muddy water went straight down into the Tube... the Engine died... I got out... Pulled off the Air Intake Tube to the Throttle Body... there is muddy water standing on the Butterfly... take off the throttle body and clean it out really good with Throttle Body Cleaner and leave it in a bag... there is still muddy water inside the intake! What Gives? What should I do... How many bolts hold the intake to the Engine? What do I need to clean? HELP ME PLEASE
95 Wrangler Inline Four! Thanks
post #2 of (permalink) Old 11-10-2002, 05:22 PM
Re: [bleep]! Muddy Water meets Engine! HELP
the intake and exsaust manifold are both conected together. i think its like 10 bolts i dont remember right off had. its realy easy though just get a new gasket for the exaust manifold and youll be ok there. however your real concern is if youve hydrolocked the motor. even if you dont think that you did if its not runing you need to pull the plugs and crank the engine over so that it purges all the cylnders of ANY water that got in. it shouldnt be to bad.
hope ya get it all fixed up soon
mike
snake_0_1 is offline
post #3 of (permalink) Old 11-10-2002, 05:39 PM
Muddy nut,
I feel for your !! Back in July I destroyed an engine by hyrolocking it. I suck my Jeep in a hole that was one used as a Bradley Fighting Position! Luckly I was able to get the Jeep out but the damage was already done. Pull the plugs and turn the engine to get out the water and then change the oil and filter, run it for about 100 miles and then change them again. Hopefully your luck is better than mine!
post #4 of (permalink) Old 11-10-2002, 05:39 PM
pontiac58's Avatar
Get the water out of that motor NOW!! Pull the plugs and crank till the water stopes coming out. You may have to shake the jeep side to side to get the water out of the intake. Once the water stop shooting out. Then try to restart. Leaving water in the motor overnight can ruin a motor. I have done this on the side of trails a few times. The YJ's just love to suck up water.
pontiac58 is offline
post #5 of (permalink) Old 11-10-2002, 05:57 PM
get it out NOW, remove plugs, put some rags over the plug holes, crank it over, squirt some engine oil in plug holes, crnak it over, use a rag to dry as much as you can from teh intake area, or some brake cleaner to try and evaporate it, and maybe even a wet dry vac with a smaller rubber hose ducttapped to the end to really get down in there, you can tell its sucking water by the sound of it.
get as much as you can out , right now, when its not milky in teh cylinders any more, I usually install the sparkplugs, but leave them almost loose, like just barely hand tight, and fire it up.
change the oil , then again in 100 miles or so, and change the plugs, and fix that intake tract so it doesnt take a drink
ozarkjeep is offline
post #6 of (permalink) Old 11-10-2002, 10:26 PM
muddybronco's Avatar
Hey Matt, you say that like you do this quite often, what's the deal man? [img]images/graemlins/grin.gif[/img]
muddybronco is offline
post #7 of (permalink) Old 11-11-2002, 12:05 AM
Re: [bleep]! UPDATE
Ok just towed the Jeep home about an hours ago... Its storming... I am waiting for the engine degreaser to set before I wash all the mud out and turn over the engine and get the mud out. Going to change the oil and such... Will update! [img]images/graemlins/smirk.gif[/img]
post #8 of (permalink) Old 11-11-2002, 07:07 AM
Muddy bronco!
I do it on Jetskis allmost daily in the summer
time!
hehe, ive had to do it to one truck, my old green Ford.
post #9 of (permalink) Old 11-11-2002, 04:12 PM
Re: [bleep]! Muddy Water meets Engine! UPDATE
UPDATE... Took out all the plugs lastnight around 3am (turned the engine over about a hundred times... no water. Around 4am finally got the Intake and Throttle Body off the car... Sprayed about four cans of Throttle Body / Intake Cleaner in the Intake and cleaned it out good... looked like it came from the Factory For Once... Let it dry... then the Intake ports on the Engine had alittle Sand Trails on it... so cleaned all that out. I replaced the plugs, oil, and oil filter. I clean the water out of everything and even took every single plug under the hood and put white electric grease on them and reinserted them. Now I bolted everything up and got ready to crank her at about 5am. It just turns over and over and over. Let it sit over night. This morning I took off the intake again and rechecked every single connection. Everything was fine. It wont start again. There is spark coming from the Coil to the Dist I know that but I couldnt get someone to help me out to see if the spark is going to the plug... but I'm about 80% sure it is. What could be the problem? Its not Hydrolocked... its turning over fine? But not firing up? Any help is greating appreciated!
post #10 of (permalink) Old 11-11-2002, 11:35 PM
Re: HELP ME PEOPLE!
TTT
