broke my bleed screw - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-09-2002, 01:16 PM
jonestown
I broke off the rear brake bleed screw what are my options on how to remove. I cant find an easy out and Im stuck at the shop. Drill and tap? Wouldnt debris/shavings contaminate the fluid. Also I stripped the front bleeders whats the easiest fix. I know Im having good luck. Nothing alot of BUD'S won't fix. Thx all for any help.
post #2 of (permalink) Old 11-09-2002, 01:31 PM
don\'t know about the rear>>
Don't know what to tell you about the rear....
Can you grab the remnents with a pair of viegrips and get it out? Maybe you can use a punch or chisel and a hammer to undo it?
As for the fronts, just use some vicegrips to lock onto them and take them out, then install new bleeders.
Mike
post #3 of (permalink) Old 11-09-2002, 01:32 PM
Re: broke my bleed screw
Year? Model?
Soak the front's in PB blaster for a day or two and then use locking pliers.. it's worth a try!
Well, the hole's already through the bleeder so what do you have to loose if you drill it out?
If the brakes are shoe type I'd remvoe the brake line and the wheel cylinder and work on the assembly in a vice. This gives better control and lets you keep things clean.
Taz'd recommend a left hand drill so if you've got 'em use 'em. Me I'd just start drilling out as much material as possible without hitting the original threads and then start trying to pick out material.
Be careful not to bugger up the OEM threads. Tapping can be a problem if you don't have a blind tap. Humm... perhaps it's time to buy a rebuilt wheel cylinder...
Looks like you've got your work cut out.
post #4 of (permalink) Old 11-09-2002, 01:41 PM
jonestown
Sorry LEVE for the lack of info: 1975 CJ-5. On the front there is very little room to get vise grips into to get a good bite. What do you mean time to buy a rebuilt wheel cylinder?
post #5 of (permalink) Old 11-09-2002, 02:09 PM
Take a look at the picture... This is a wheel cylinder that's on the other side of the brake backing plate. It's removed by taking out the two bolts on either side of the bleeder screw.
NAPA Part #
Left Rear - TSW4617509
Righe Rear - TSW4617510
Cost is about $11 each
Left Front - TSW4636017
Right Front - TSW4636018
Cost is about $14 each.
post #6 of (permalink) Old 11-09-2002, 02:43 PM
What Leve said. You can fiddle with it for hours, bugger up the threads, get shavings inside, and probably not accomplish anything unless you take it off so that you can work with it on the bench. And then you still need to go to the parts house for a new bleeder, which they might not have.
Jim_Lou is offline
post #7 of (permalink) Old 11-10-2002, 06:22 PM
I Do This For The Glory
JEEPN's Avatar
Perfect time to get some speed-bleeders.
I would also douse the front in PB Blaster, and use VISE-GRIPS (not the Chinese JUNK look-alikes), put them on there as had as you can get them to bite, and they should move. I have had the same problem a number of times.
For the rear I'd soak it in PB once again, and try an easy-out before the drill bit. By the time you get to the drill bit, you're better off just replacing it. Those left-handed bits are the cat's meow, but they can be hard to find, so guard them well. Also don't use them for normal drilling.
JEEPN is offline
post #8 of (permalink) Old 11-10-2002, 06:39 PM
Official Curmudgeon
CJ7Taz's Avatar
[/ QUOTE ]Thanks for the mention, but no I wouldn't.
That other post was a newly inserted bolt and not tight once the head broke off. This time I'd recommend the vice-grips and if that don't work, just replace it, it ain't worth the frustration.
CJ7Taz is offline
