- Jeep-Short Wheelbase
- - low compression in #2 only showing 89 lbs
(https://forums.off-road.com/jeep-short-wheelbase/142884-low-compression-2-only-showing-89-lbs.html)
Totally rebuilt 258 with 4.0l head. Did a general compression test yesterday. All clylinders reported 170 bs, except #2 which showed only 89 lbs. On a recheck the same results. Took the oil can and added a little oil, ran the test again. Exactly the same pressure. About 10,000 miles on the engine. What could be the cause?
Thank you Fran |
Re: low compression in #2 only showing 89 lbs
Typically with the oil squirt ..it tends to point to a valve. This is somewhat odd given the short length of time that the head was on the engine.
Can we assume that the head was "serviced" before installation? Have you pulled the valve cover to look at the rocker action? |
The head was a brand new 4.0L head directly from Clifford Performance. It has Chevy S.S 1.92/1.50 valves installed. I left the commpression gauge hooked up for a while and the pressure stayed at 89 lbs. I am getting alot of blow-by from the crankcase. Oil is evident around the breather, the distributor shaft, and other opening around the engine. Would a leak down test be the way to solve this mystery?
Thank you! Fran |
Uh Oh, I hope not - but sometimes when you put a new or good
head on an old engine that happens. The head works so good holding compression that it blows the old tired weak compression rings out. Yes, a leak down test would be in order now before taking it apart. |
My guess.. the problem's in the head, I'd:
1. Pull the valve cover. 2. Rotate the engine by hand. 3. Watch the action of the valves and rockers with the compression guage attached. 4. Compare this another cylinder. You may find a valve not closing, bent stem, etc.. |
Rich,
It is a brand new motor. Overbored and honed. All new stuff top to bottom. It runs great. Tremendous power all the way though to range. Just got this weak cylinder. I hope it is in the head. Thank you Fran |
Well, we have used a modified sparkplug shell to put compressed air into the cylinder. If the air comes out the intake - intake valve, same for exhaust. Air out the oil cap - usually rings, air out the side or the radiator, head gasket. Air out the oil cap can be head gasket. Needless to say, you need to start with on the compression stroke with the valves closed. The air pressure will usually push the piston to the bottom.
As LEVE suggested, pop the top off and look.
You may see something in the valve action - like bent pushrod, pushrod fell off, loose rocker etc. Or, you may find the cam's gone flat - hopefully not that, it's more work! Believe it or not, I've seen cylinders with no pushrod on the intake valve at all still give some compression. The suction action of the piston can lift the valve enough to get a small gulp of air at cranking. I wouldn't believe it if I hadn't seen it. Bent pushrod? Make sure the valve still operates freely. One trouble lately is the MTBE in gasoline forms a soft carbon, and makes valves stick, bending the pushrod. Saw it recently on a 454 with less than 250 miles on it. 3 pushrods bent like pretzels. No it wasn't running too rich either, TBI. I think, but not sure, since the truck sat for about 6+ months or so until the engine was built, the MTBE in the near full tank chemically changed into something that caused the excessive carbon. The carbon was strange too. Usually carbon is a hard substance, this was a crumbly, almost soft, stickey stuff. It felt soft, porous, but was hard enough to scratch glass. I've heard about it before, but this was the first time I saw it. We had to pull both heads and completely redo them, guides and all. Guides looked like you could drive a truck through them. Let that be a lesson for all, if you store something, get that "environmentally friendly" cancer causing MTBE laden gas out of the tank. It goes bad fast. If everything looks good, do what Taz suggested, pressurize that cylinder and see where the air goes. A leak down tester is almost the same thing, just has a gauge to see how bad is bad - you know it's bad, you just need to know why. |
Where can I buy the test equipment for a bleeddown test and is it a difficult operation to accomplish.
Thank you Fran |
you can use a $25 compression guage kit, just take off the gauge, and hook your air compressor to teh hose that screws into teh sparkplug hole, make sure the cylinder your testing is at TDC, and the vavels are closed, and also start at a low air pressure ( abotu 20psi) then slowly increase until you can hear it hissing, mke sure its in Nuetral, and teh wheels are chocked!
I did it on a suzuki once and it was enough pressure to roll teh car forward. |
User Alert System provided by
Advanced User Tagging (Pro) -
vBSecurity v2.2.2 (Pro) -
