Needed, some kind of electrical push/ pull device - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-07-2002, 06:49 PM Thread Starter
pontiac58's Avatar
I have the old warn bellvue upright winch. The brake and clutch were orginally controlled with cables. Well i have the cables but there are no way to run them with out kinking the cables. So after much thought, I had a brain storm. I need some kind of electrical push/pull device. Something that when i flick a switch the device would pull the brake on and when the switch was released the brake would release. My best friend said try a door lock, but im not sure if they could take the weather and the abuse. Any ideas would be helpful.
pontiac58 is offline
post #2 of (permalink) Old 11-07-2002, 06:55 PM
Re: Needed, some kind of electrical push/ pull device
I've done similar stuff like you want on production equiptment. Solenoids(sp?), but I don't know if you can get them for 12V for what oyu want. Are you running OBA, if so get some small air cylinders, they are cheap.
shawnscj is offline
post #3 of (permalink) Old 11-07-2002, 07:06 PM
you dont even need onboard air - think the other way, and install a vacuum pull unit such as the ones used for cruise control, or in central locking systems ( door locks) alternately, some small air cylinders can be plumbed for vacuum use. the door pulls generate 3-5 lbs pull...I honestly dont know if that'd be enough for your use or not.
to control it, try and find a europen can that has central locking ( ie, Mercedes, or Audi) they have a manual vacuum control valce inside the drivers door that you could fit to the dash. another option is a 12v vacuum solenoid used to control emissions gear..again, I know Mercedes, Volvo, and VW/Audi have used them as I use one to control the vacuum-off system on my diesel.
chris
wanderer4x4 is offline
post #4 of (permalink) Old 11-07-2002, 10:04 PM
Pooh-Bah
pbmcauliffe's Avatar
I have used numerous door lock actuators in various situations. Yes, an standard door lock motor will only generate up to about 7-10 lbs of force, but I have also used larger units that will handle up to around 75+ lbs. The larger units do get expensive though, some are available thru here web page
pbmcauliffe is offline
post #5 of (permalink) Old 11-08-2002, 08:12 AM
Newbie
Hi everyone, long time reader, first time poster. Was just thinking, if an electrical solenoid wasn't strong enough, would a hydraulic clutch cylinder work? Just attach the reservoir to a throw lever in the cab to engage it. It would be tough enough to take abuse and be weather proof.
Great board, Have gotten alot of good info here.
Dave
Jeep_pression is offline
post #6 of (permalink) Old 11-08-2002, 01:43 PM
Try a GM starter solenoid. My only concern would be duty cycle. I don't think they are intended for being energized for long durations.
