Re: Temperature Gauge Question
[img]/wwwthreads_images/icons/tongue.gif[/img] Just guessing on this, but if it is anything like our 304, the problem is that the hole that the electric sender goes in is too tiny to take a bulb for the direct-reading gauge. There is a larger hole in the manifold, but it has the CTO valve in it. I guess you could tee in under the heater hose, but even that is taken by some smog setups with another CT valve tee'd in under the heater water outlet.[img]/wwwthreads_images/icons/frown.gif[/img]
CJDave
