Re: Axle question
[img]/wwwthreads_images/icons/tongue.gif[/img] You either have to count the turns, look for the axle code, or get some little moonguys[img]/wwwthreads_images/icons/crazy.gif[/img][img]/wwwthreads_images/icons/laugh.gif[/img] to squeeze in through the oil filler hole and check the ring and pinion.[img]/wwwthreads_images/icons/tongue.gif[/img] I have a list of axle codes if you need them, but it is best to verify it by turning to be sure it has not been changed. OR you could do like a lot of Jeepers do, and go around thinking that the driveline will "absorb" (yes, I have SEEN posts that say that) the difference. SHEESH![img]/wwwthreads_images/icons/blush.gif[/img][img]/wwwthreads_images/icons/shocked.gif[/img]
CJDave
