ready to start rebuilt 258 ??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-05-2002, 08:50 PM
gman
Finaly ready to start my motor, have the last minute ques. installed painless perf full harness,borla header,comp.cam,weber,did the tr upgrade,flex fan,hayes clutch. the ques? I adjusted the clutch so the release arm has about 1/4 play, this translates to about 2" play at the clutch pedal, feels terible to the foot, am I doing this wrong? I filled the radiator with 50/50 mix but am now thinking there is nothing in the block is this ok ?? please help, Getting anxious to start it but would like to no I'm not screwing up at the last minute thxs gman
post #2 of (permalink) Old 11-05-2002, 09:24 PM
Re: ready to start rebuilt 258 ???
I've always adjust my clutch so that it felt good on my foot. Seriously snug it up a bit till it feels right, just don't over snug it. You should have some play, but it will be minor. I wouldn't worry about your coolant, just start it with the radiator cap off, and continue filling it as needed. This will help bleed any air out of your cooling system also. Don't forget to prime the oil pump. Good luck.
post #3 of (permalink) Old 11-05-2002, 09:42 PM
gman
yeah, I guess I'm just getting nervous, already primed the motor, and just finished making the wires for the tr upgrade, I used taylor universals and cut them to fit. I heard someone talking about burping the system, and that got me thinking about the coolant.
post #4 of (permalink) Old 11-06-2002, 08:28 AM
Tippy's Avatar
Make sure you follow the directions for breaking in the cam. They say to run the engine at about 1500-2k for the first 30 minutes, changing the RPM periodically to direct oil splash to differnt areas on the cam. After 30 min, change the oil.
Tippy is offline
post #5 of (permalink) Old 11-06-2002, 08:41 AM
how much coolant did your engine take to fill?
it should take about 2.5 gallons. if you want to try to burp it, try disconnecting one of the heater hoses, or, if the hoses go thru the intake manifold, try to figure out which fitting on the intake manifold is for the CTS (coolant temp controlled vacuum switch) and slowly remove it to see if there is coolant in there.
matt
jeepnmatt is offline
