Helicoil - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-05-2002, 10:55 AM Thread Starter
Helicoil
I stripped one of the six bolt holes in my crank shaft flange that hold the fly wheel on. Got a Helicoil kit and driled and taped the hole for the Helicoil, that all went well. But when the I installed the thread coil, the flange it only 1/4" deep, so you must cut the coil. After three coils I got the coil cut right. It is not as easy as installing the coil in a deep hole. So if you screw the coil on the bolt and use that to find were to cut the coil off, also use the best cutter you have.
Woodsrider is offline
post #2 of (permalink) Old 11-05-2002, 12:55 PM
Re: Helicoil
Helicoils are tougher than nails. That can be good and that can be bad. In this case 1/4" is not a lot of depth. But hey, if the OEM bolt can exist there, so can a helicoil. The little trick here is to cut the dang thing. I use a cutting disk (drill mounted's find, but I use an air die grinder.) and a sacrifical bolt. Once this is done I take the remains over to my grider and dress up the top of the cut so that it's level. Then I insert it into the hole and drive it in and use a screwdriver to drive the last thread in, making sure it's flush with the top of the hole.
