Transmission torque mounts on CJ?????? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-24-2002, 08:20 PM Thread Starter
pontiac58's Avatar
Ok maybe i am just going nuts here. I know i have installed a couple of these but for some reason i dont remember having this question before, but the others i have installed were on friends rigs and it was always a hurry up and slap it in type deal, where they just didnt care.
I know i always had to add a washer to the bottom where it attaches to the skid plate so there wouldnt be any play in that area and i think i have added spacers in my question area.
So here is my question: The steel channel that comes from the trans is 1/8" or 3/16". But the gap in the rubber bushings is 1/2" or 5/8". Is it supposed to be that loose in that area? What good is it with that much space? If the mount were to go all the way up to the top bushing the trans mount would take all the abuse before the torque bushing would do anything. So should i or shouldnt i shim that area tighter??
pontiac58 is offline
post #2 of (permalink) Old 10-25-2002, 12:49 AM
Re: Transmission torque mounts on CJ??????
Jim, I think you could take up a little of the play without hurting anything. Assuming you are running stock engine and tranny mounts. If you have swapped out everything to poly or to a MORE style engine mount you could probably take out a lot of the play.
BigHG is offline
post #3 of (permalink) Old 10-25-2002, 05:10 AM
I had the same problem, and shimmed mine up tight with some washers. They inevitably come loose again, I used a Nylok nut to help the situation.
AllLockedUp is offline
post #4 of (permalink) Old 10-25-2002, 05:33 AM
One of my transmittion mounts broke a while back and I needed a quick fix to get me home from school. I had some bushings left over for my sway bar disconnects, and as it turned out they fit really well. Used a bunch of washers to shim and a nice long bolt. Worked like a charm, solid as heck and I still haven't replaced it with a stock type mount.
Olin18 is offline
post #5 of (permalink) Old 10-25-2002, 11:26 PM
jamgood96's Avatar
If I'm thinking of the same thing, my YJ's got the same problem. I replaced the bushings with new poly ones from Energy Suspensions and they're a little smaller and have lots of play in them. Also, anyone else have problems of bending the crap out of that bolt since it hangs down below the skidplate/crossmember?
jamgood96 is offline
post #6 of (permalink) Old 10-26-2002, 07:12 AM
Are we talking about that little steel bar that comes off the transmission mount towards the side, and then has a bolt and bushings that drop down through the skidplate?
When my Jeep was new those bushings were rattley loose. One time when I was putting the transmission back in I tossed the whole thing in the scrap bin. Never could detect a difference.
At the time, I decided that if there was a problem, I'd mount a small shock absorber between the head and the frame rail, where it would really control the engine rocking, but like I said, no problem.
Jim_Lou is offline
post #7 of (permalink) Old 10-26-2002, 08:10 AM Thread Starter
pontiac58's Avatar
Well between what i read here, and talking with two of my friends, both of which i have much respect for. I have two ideas.
One set up the way the factory did it. Which doesnt mean it was right. We all know how jeeps were put together. [img]images/graemlins/grin.gif[/img]
Two, is to put it toghether with shims and make the mount acutally do something.
So after thinking about it for two nights and finally remembering what jeep i did it on before, i am going to shim it tight.
