Could my engine actually be running too cold? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-22-2002, 03:45 PM Thread Starter
I have an '87 YJ with a 258 and a Howell FI setup. I noticed recently that the temperature guage is registering the temp running pretty cool even after the engine has had a chance to warm up and even after being driven for a while. It used to go up about a quarter of the way, now it stays near the bottom. I felt the hose going to the radiator and it feels warm, but not overly hot. I ordered a new guage today because I figured maybe the guage is faulty. Could the engine actually be running too cool? What would cause this if it is? Is it harmful to the engine if it is running too cool? Thanks in advance for the responses.
Donny
donnyg is offline
post #2 of (permalink) Old 10-22-2002, 03:54 PM
Re: Could my engine actually be running too cold?
Check your thermostat, it could be stuck open. You may not be driving long enough for the engine to warm up if it is stuck open. As far as it being damaging, I don't really know.
jlove86CJ is offline
post #3 of (permalink) Old 10-22-2002, 04:09 PM
I had this same problem with my 86 CJ. Yes, it's most likely the thermostat. I replaced mine and that fixed the problem. By running too cool you might not do any damage, but your fuel economy will most likely decrease to some degree.
shad0wrider is offline
post #4 of (permalink) Old 10-22-2002, 04:13 PM
Yes it can damage the engine at too low a temp. Engine tolerances are set at a certain measurement, this measurement is taken when the engine is at a certain temp, around 200 degrees, when the metal parts within the engine have expanded. Lower temp, means the engine is running outside those tolerances and wearing faster then it should.
Also, to get proper readings to the ECM, the temp must be above 185*.
W.C. is offline
post #5 of (permalink) Old 10-22-2002, 05:03 PM
Tippy's Avatar
195*, 195*, 195*! Replace your old thermostat. They are only about $5-6 bucks at carquest plus $0.50 for the gasket.
Tippy is offline
post #6 of (permalink) Old 10-23-2002, 12:22 PM Thread Starter
There are different temps for the thermostats that I see companies sell. Which is the one I want? What was the stock one? Any brands better then the other? Thanks.
Donny
donnyg is offline
post #7 of (permalink) Old 10-23-2002, 05:13 PM
Tippy's Avatar
195*; 195*; 195*!!
Tippy is offline
