clutch master cylander problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-19-2002, 12:45 PM Thread Starter
Hey guys, I've been having problem with my clutch where its is hard to shift into gear. And it is the clutch because in first gear with the clutch pushed in the jeep will keep moving very slowly. I put a complete clutch job in it 20,000 km ago which included new clutch disk, new pressure plate, new throughout bearing and slave cylander, new pilot bearing and I had the flywheel machined. It still was a litte hard to shift into gear but now it is almost impossible. So the only thing left is the master and I just put a rebuild kit into it. I bled it and it worked great, before the clutch would engage and the very end of pedal travel and now it does it in the middle, like it should. But today it was back to the way it was before.I have no fluid loss and the pedal doesn't feel as firm as it was.the one thing that I did notice is when I push the pedal down a little bit of fluid goes back into the master, and since the plunger(I think thats what its called) is new the hole where the fluid is sucked back into the master cylander's bore must be worn out. And I don't imagine you can fix this without a new master cylander. What do you guys think? Thank .
YJ_88 is offline
post #2 of (permalink) Old 10-19-2002, 06:26 PM Thread Starter
Re: clutch master cylander problem
btt
YJ_88 is offline
post #3 of (permalink) Old 10-20-2002, 08:42 PM
First make sure you don't have too much play between the slave cylinder and the throw out fork.
All the bearing needs is 1/16" off the clutch fingers ... enough so you can just jiggle the fork.
Your guy may have left the 'bullet' part off from the end of the slave's pushrod.
Jaffer is offline
