my ring and pinion is singing. Help me fix it!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-16-2002, 05:30 PM
I had put in a Detriot locker w/ 4.10's last years. I found out, after a hole appeared in my AMC 20 diff. cover, that a couple of bolts fell out of the ring gear and the rest were just finger tight. After cleaning everything out of the housing, I inspected the ring and pinion. Everything looked fine. (I'm lucky!!) I put some new bolts in with lock tight and did the same with all the others that were loose. I didn't pull the locker out of the housing and did two or three bolts at a time making sure not to looses the ring gear entirely. After getting the cover on and fluid in, she sings at high speeds. Any ideas why?? Did the ring clock on the locker while loose? Would this cause singing? Where do I go from here??
post #2 of (permalink) Old 10-16-2002, 06:24 PM
Re: my ring and pinion is singing. Help me fix it!!
Did you torque the ring gear bolts to spec? Recheck the gear pattern just to make sure that nothing in the setup is out of whack.
AllLockedUp is offline
post #3 of (permalink) Old 10-18-2002, 12:13 PM
I retorqued the ring gear bolts 5 more lbs. then spec. I didn't want then to back out in another year or so. That really wounldn't affect the clearance between the ring and pinion, would it?? If anything it would "move" the ring gear further away from the pinion causing more clearance.
