steering problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-11-2002, 04:37 PM
steering problem
I have a 77 cj5 and my steering is a little loose. the real problem is it is all over the road. i also have shackle that are just plates of steel and are two inches longer. what could be the cause of my wandering jeep. <font color="red"> </font color>
post #2 of (permalink) Old 10-11-2002, 06:21 PM
Re: steering problem
Hurricane-
I think that your problem may be a little bit of a lot of things all rolled together. Did the jeep come with this problem or has it just all of a sudden gotten bad or has it slowly reach this point?
Possibles in my book are-
1. U-joint in steering column loose or wearing out
2. Bad or loose steering box
3. Bad ball joints
4. Bad rubber bushings at the springs/shackles
5. Big tires that are near the end of life and are "tracking"
6. Bad steering stabalizer
7. Bad front wheel bearings
Good Luck!
Kriss
post #3 of (permalink) Old 10-11-2002, 10:05 PM
It hasn't always had this problem. But i was wondering if it could be the shackle lift. They are two inches longer than stock so im not sure how much lift that is but there is no crossmember.
post #4 of (permalink) Old 10-11-2002, 10:20 PM
That could be a big portion of the equation right there - 2" oversize shackles will flex quite a bit, especially the "plate type" without a stiffener. Shackles that big also screw up your caster, which in turn will adversely affect steering.
post #5 of (permalink) Old 10-11-2002, 10:25 PM
Do you think that a shackle reversal and revolver shackles would be an ok setup. I plan on at least a 2.5 suspension lift and 33's.
post #6 of (permalink) Old 10-11-2002, 10:36 PM
I'd say a reversal with heavy duty stock length shackles. For lift, replace the springs, don't fool with the shackles and/or body lifts. I personally don't think revolvers belong on the street - only on trail only rigs.
post #7 of (permalink) Old 10-13-2002, 12:00 PM
Tall shackles are never a good idea. If you want lift, swap out the springs. The shackle reversal has it's draw backs too. I would do more research before spending the money. Then if it looks right for you, go for it. I will not make that conversion on my 78 CJ5.
Kriss
