Winch no worky - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-17-2002, 06:05 PM
Winch no worky
Superwinch S9000. It worked the last time I used it, and no, it didn't overheat or anything. Now it doesn't work. When I hit the button, it doesn't move in either direction, and doesn't make any noises (no clicks, whirrring or anything).
The cable connections to the battery are good. Any ideas?
post #2 of (permalink) Old 09-17-2002, 07:12 PM
balanced
Re: Winch no worky
If you have cheched the connections to the battery then what type of control cable do you have? My Warn has a cable that plugs in to run the winch in & out. If yours has one of those check the connections on both ends for any signs of corrosion.
Outside of that I believe that under the cover somewhere there are some solanoids that work the motor. That would be the other option.
Good luck
post #3 of (permalink) Old 09-17-2002, 07:16 PM
Carpal \'Tunnel
knifeboy2's Avatar
Re: Winch no worky
You have checked that the connections are good to the battery. Have you checked that the power is going all the way to the winch? I had a similar problem once and I kicked myself when I realized it was just a blown fuse. Follow the cables from the battery to the winch to make sure that no peice in between has failed. If the power is making it to the winch then I don't know what the problem is.
knifeboy2 is offline
post #4 of (permalink) Old 09-17-2002, 07:22 PM
Raduckal's Avatar
Re: Winch no worky
If you are useing a remote cable, check it's connections too. You can jump the terminals at the switch connection point to rule out any remote/remote cable problems.
Raduckal is offline
post #5 of (permalink) Old 09-17-2002, 07:29 PM
Re: Winch no worky
I got it. It was a bad connection at the switch. Thanks y'all.
