What Cam do I need and where do I get one? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-16-2002, 08:41 PM
I am running a 258 with Offenhauser intake and a Holley 390 carb with an upgraded ignition, I also have headers. I need a cam so I am not blowing fuel out the exhaust. What cam do I need and where do I get it? I am not to literate in figuring out the lift and all that. I appreciate any help ?
Sheb
post #2 of (permalink) Old 09-16-2002, 11:14 PM
Re: What Cam do I need and where do I get one?
I really need some help here guys
post #3 of (permalink) Old 09-16-2002, 11:28 PM
I would call a cam company like Crane, Comp Cams. and tell them your setup. they can suggest a cam that will be perfect for you. Wade
wades_76_CJ7 is offline
post #4 of (permalink) Old 09-17-2002, 07:57 AM
I am running a Crane torque cam I ordered from 4-Wheel Drive Hardware. It's the one with curve 1500-4500. Don't have the duration and lift numbers handy, but you'll see which one I am talking about. My engine is bored .060 over, and I am running the factory intake with a Holley 350 2-barrel, header, full exhaust, decked head, 3-way valve job and a few other goodies. The cam made a huge difference in performance, and the price was reasonable. I'd go with that!
post #5 of (permalink) Old 09-17-2002, 09:38 AM
Tippy's Avatar
I put a COMP cam and lifter kit in my 258 w/ mpi and the 4.0 head. It has 260 advertised duration w/0.447 lift. RPM range is form 1200 - 4400. It idels a little rough at 800 rpm, but once you get it up to its power range it is smoth.
Tippy is offline
post #6 of (permalink) Old 09-22-2002, 09:50 PM
Thanks Tippy
Do you think that iyou setup for cam needs would be equaled by the 4bbl carb and offey intake?
post #7 of (permalink) Old 09-24-2002, 01:45 AM
I called Competition Cams today and it rang and rang, tried the number again and the same thing. So I called Crane Cams the guy was great!!!!! He spent time with me and really helped me out. He reccomended Cam part # 753941 the specs were 484 Intake 512 Exhaust 112 Lobe seperation angle Duration 50 degrees 216 Intake and 228 Exhaust. I am also going to run a late model timing chain 89-99 to reduce the slop in the cam.
He also informed me that there is only 1 company that makes lifters now (never figured that). I was going to use roller rockers but can't find them.
By the way they were 129.00 versus 4wd.com's 139.00.
post #8 of (permalink) Old 09-24-2002, 12:09 PM
Does someone know the stock cam specs for a 258?
My 258 has an aftermarket cam (Wolverine brand), and I have the specs on that, I am just trying to compare that to stock to see if my idle problems are cam-caused.
Thanx.
pnut is offline
post #9 of (permalink) Old 09-24-2002, 03:29 PM
You might want to talk to Clifford Performance in CA. They specalize in straight six's, and offer a few differant cam options depending on what you're running.
www.cliffordperformance.com
