Ignition gurus ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-14-2002, 11:22 AM Thread Starter
Ignition gurus ?
HI all ,1980 CJ 258 TR upgrade ,including the TFI coil,
The problem I posted a while ago about has come back to haunt me
Driving along ,everything fine ,the engine will cut out, no sputtering like running out of gas.....fuel filter changed..... It just dies as in lack of power..
1 If you push the clutch in it stays shut off and needs restarting ...
2 If you leave the clutch in, or depress and let it out, It will restart itself just like jump starting it...
I took the distributer apart and tightened the ground screw inside there and checked for any obvious problems,like frayed wires or anything,put it back together and it ran fine till last weekend when it did it again. Now it seems worse.so could it be ? without replacing everything...
Bad coil
bad coil wire
module going
sensor assembly in the dist.
something else I may be overlooking?
unhumen is offline
post #2 of (permalink) Old 09-14-2002, 12:26 PM
Re: Ignition gurus ?
I had the same problem with my 88 Wrangler. Replaceing the ignition module fixed it. Don't know much about an 80 CJ and it's ignition system though.
post #3 of (permalink) Old 09-14-2002, 05:05 PM
It sure sounds like a module problem to me. I think that I'd swap it for a different one and see what happens, but keep the old one for a spare.
Jim_Lou is offline
post #4 of (permalink) Old 09-15-2002, 05:11 PM
replace the module, its easy, and its cheap.
also, try disconnecting the clutch switch. its sounds like the clutch switch is getting a bit crusty and just doesnt want to play that silly game anymore.
mine never had that 'problem' of having to push in the clutch to start. doesnt bother me, but then again, i am the only one that drives it.
rock_monkey is offline
post #5 of (permalink) Old 09-15-2002, 08:12 PM Thread Starter
Well today I replaced the module with a MSD I had sitting on my shelf ...the module was just replaced before I got the MSD so I just put it on the side,for the rainy day that just arrived...I thought I had this problem fixed a few weeks ago when I tightened the grounding screw in the distributor,and it went away for a few weeks...so weather this is the actual problem or not remains to be seen.
I thought it might be the pickup sensor unit in the distributor itself going bad...this is a Remanufactured Distributor only a few months old.
unhumen is offline
