HELP!! Frozen Clutch - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-11-2002, 03:45 PM Thread Starter
I recently purchased a 78 CJ-7 with a t-18 tranny. The CJ has been sitting for 2-3 months. The clutch is "frozen", any ideas of how to fix this? Will I have to drop the bellhousing and get to the clutch or is there a easier way to try first? Thanks
Jeeprugger is offline
post #2 of (permalink) Old 09-11-2002, 04:11 PM
Re: HELP!! Frozen Clutch
By frozen do you mean that you cannot disengage it? Can you push the clutch pedal in at all?
AllLockedUp is offline
post #3 of (permalink) Old 09-11-2002, 05:45 PM
Stick it in 1st. Push the pedal down. Have another vehicle pull or push a few yards and it should free up.
Jim_Lou is offline
post #4 of (permalink) Old 09-11-2002, 07:04 PM Thread Starter
Lockedup-
The cultch will push in, When I crank the engine, I try to put it into any gear, and it's like hitting a brick wall.The throw out bearing or clutch or pressure plate is stuck.
I apperciate you help.
Jeeprugger~
post #5 of (permalink) Old 09-11-2002, 07:15 PM
Try doing what Jim_Lou suggested. It usually works.
post #6 of (permalink) Old 09-11-2002, 08:53 PM
What happens when you try starting the motor with the clutch pushed in and the tranny in 1st gear? (Before you try this make sure that you have a clear space in front of you.) If the jeep goes forward as the motor turns even though the cluch is pushed in, then the pilot bushing is sticking to the output shaft of the tranny.
Good Luck!
Kriss
post #7 of (permalink) Old 09-13-2002, 08:04 PM Thread Starter
Thanks for the tip, it worked just like you said! The 7 is up and running.
Jeeprugger~
