Help!!! Tranny problems - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-09-2002, 04:50 PM Thread Starter
I have an 81 Cj with a 350 and a T176 4 speed. Well today when I was driving I couldnt get it in gear but I was able to get where I was going. Then I was getting ready to leave and I was trying to put it in first and It felt like I was hitting a wall. I couldnt get it in any gear at first then I was able to get it in third but trying to go to another gear it felt like it popped out of socket or something. I could twist the stick in a circle and it move it all around. So I had to leave the jeep. Has anyone had a problem like this? Does it sound like an easy fix. Im just trying to get an idea before I have to call a tow truck and and spend money on getting it fixed. Im getting ready to sell it, because I need money for my other jeep. Please Help!!
rubiconvict is offline
post #2 of (permalink) Old 09-09-2002, 05:22 PM
Official Curmudgeon
CJ7Taz's Avatar
Re: Help!!! Tranny problems
This one's easy. Pull the floor cover plate over the tranny/t-case. In the tranny tower, where the shifter fits, there is a tapered dowel pin on each side. One hase come loose. If you are lucky, it's still laying right on top of the cover. Remove the shifter by pressing down on the retainer ring and turning. Replace the pins and put a hose clamp around the tower to hold the pins in. Reinstall the shift lever.
DON'T HAVE IT TOWED, not until you search for the pin anyway. I don't know if you would have any luck finding a new one without going to mail order.
From your description, you may also have the warn shiftgate problem. If you make clean H pattern shifts, you can live with it.
CJ7Taz is offline
post #3 of (permalink) Old 09-09-2002, 05:24 PM
it sounds like the squarish ball part of the bottom of hte shifter stick has come out of one or both of the shift rails.
you can take the cover off ( thru te floorboard) and readjust and put it back inside the rails like it should be.
ozarkjeep is offline
post #4 of (permalink) Old 09-09-2002, 08:09 PM Thread Starter
Yea, thats kind of what I thought Happened too. Thanks fellas. I'll check that out tomorrow.
post #5 of (permalink) Old 09-10-2002, 09:45 AM Thread Starter
When i first bought the jeep the guy told me it was a T-176 so I just [censored] u me d it was but I got to lookin and found out its a SR-4 because it has "Borg Warner" and "Ford" stamped accross it. I dont know if this would make a difference in what you told me but I took off the 3 bolts that hold the shifter in and the whole thing came right out. Should it do that?? I can line the fork at the end of the shifter with the shift rod and go through the gears, but the shifter will sometimes twist and come out, like it did before. So should there be a pin or something that should go through the stick shift, to keep it from twisting. Looks to me like if the shifter wouldnt twist it would work. But im not sure if there is a pin because Im looking in a quadratec mag, at the parts break down and they dont list anything for the shifter part. Any suggestions????
post #6 of (permalink) Old 09-10-2002, 09:50 AM
the PIN if it has one ( it probably does) is where the shifter meets the top of the trans cover, there is a half moon that rest on the cover, and the pin should be on one side of that into the shaft.
im not fameliear with that trans though, so above info might not be accurate.
post #7 of (permalink) Old 09-10-2002, 06:37 PM
z50k2's Avatar
Matt, how is the body? any rust? I may be interested in buying it..send me an e-mail.
Thanks, Ricky...seeya..
[email protected]
z50k2 is offline
