CJ 5 shift pattern - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-08-2002, 02:50 PM Thread Starter
Apprentice
CJ 5 shift pattern
hi all. i just bought my first jeep(also fist 4 wheel drive vehicle), a 74 CJ5. no pics yet, or id post em. kinda rusty, kinda beat up, but hey, its a jeep. my question is, what is the shift pattern for my 4 wheel drive?. the knob is too worn to read, and the shifter has 4 positions. i suppose i could jack it up and see what each does, but thought it best to ask for help. anything would be helpful, including general info on jeeps and CJ5s. thanks for everything. sparky
sparky96181 is offline
post #2 of (permalink) Old 09-08-2002, 03:02 PM
Re: CJ 5 shift pattern
4Hi is all the way forward, then 2Hi, then Neutral, and 4Low all the way back. Check it, though, because you never know what someone might have done to it.
Jim_Lou is offline
post #3 of (permalink) Old 09-08-2002, 03:26 PM
Carpal \'Tunnel
knifeboy2's Avatar
I know someone will say it so I guess I can do it...please fill out your profile. It helps more than you can think. Find out what mods have been done to the CJ if any. Keep reading this board and you'll learn very quickly. The shift pattern previously mentioned is the stock settings. I have a 2 Low on mine, and have 5 spots to shift it in, but for all you know the previous owner of your CJ had changed some things around. Congrats on buying a Jeep and although there may be times when you just want to push it off a cliff, don't, just keep telling yourself its a classic car and needs loving.
knifeboy2 is offline
post #4 of (permalink) Old 09-08-2002, 04:15 PM
It's NOT a CAR, Nick. Classic or otherwise. Shame on you [img]images/icons/smile.gif[/img]
Jim_Lou is offline
post #5 of (permalink) Old 09-08-2002, 04:27 PM
Carpal \'Tunnel
knifeboy2's Avatar
Oooops!!!! How did I type that?!? Shame on me!!! I appologize to all who I may have offended.
post #6 of (permalink) Old 09-08-2002, 06:09 PM
by rights you should have a dana 20 transfercase in it....and it should shift forward to back - 4H-2H-N-4L -
but mine is the same as nicks , it also has 2L....aparently this is a (handy)factory fault...after a little wear the linkage allows 2L to be selected also .....mine is
4H - 2H - N - 2L - 4L ......if you cant get it in 4L check to see if the shifter is hiting the floor(a common problem) ..also you say that this is your first 4x4...just a friendly warning - never put it in 4wheel drive when on dry pavement,the reson for this is ,when you do a turn(even a small one)the front wheels travel slightly further than the back ones ,and in 4x4drive the front is locked into the back,so something must give , usually its just a tyre spin but sometimes you'll break an axle or a uni etc. i learnt the hard way , i did a about 1/4 of a turn on pavement(to see if 4x4 was working,first time i ever tried) and it was enough to destroy my rear diff......
welcom good luck..
post #7 of (permalink) Old 09-09-2002, 07:34 AM
Melcor, your right about that shift pattern. The interesting thing is that in my transfer case, it was like that brand new, or at least with only a few thousand miles.
I'm always careful about using it because I suspect that everything might not be fully engaged, and because it would be possible to put a terrible load on the rear drive train.
The best use I've found for it is maneuvering trailers around. The low speed makes up for my lack of practice [img]images/icons/smile.gif[/img]
Jim_Lou is offline
